<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ESP-Now-Serial-Bridge on M5Atom S3]]></title><description><![CDATA[<p dir="auto">Hi,<br />
First Post so be gentle please :)<br />
I’m trying to get this code to work on a M5Atom S3 with Arduino IDE.</p>
<pre><code>/*********************************************************************************
 * ESP-Now-Serial-Bridge
 * ESP32 based serial bridge for transmitting serial data between two boards
 * The primary purpose of this sketch was to enable a MAVLink serial connection,
 *   which I successfully tested at 57600 bps.  In theory, much faster buad rates
 *   should work fine, but I have not tested faster than 115200.
 * Range is easily better than regular WiFi, however an external antenna may be
 *   required for truly long range messaging, to combat obstacles/walls, and/or
 *   to achieve success in an area saturated with 2.4GHz traffic.
 * I made heavy use of compiler macros to keep the sketch compact/efficient.
 * To find the MAC address of each board, uncomment the #define DEBUG line,
 *   and monitor serial output on boot.  Set the OPPOSITE board's IP address
 *   as the value for RECVR_MAC in the macros at the top of the sketch.
 * The BLINK_ON_* macros should be somewhat self-explanatory.  If your board has a built-in
 *   LED (or you choose to wire an external one), it can indicate ESP-Now activity as
 *   defined by the macros you choose to enable.
 * When uploading the sketch, be sure to define BOARD1 or BOARD2 as appropriate
 *   before compiling.
 * -- Yuri - Sep 2021
 * Based this example - https://randomnerdtutorials.com/esp-now-two-way-communication-esp32/
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files.
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software.
#include &lt;esp_now.h&gt;
#include &lt;WiFi.h&gt;
#include &lt;esp_wifi.h&gt;
#define BOARD1 // BOARD1 or BOARD2
#ifdef BOARD1
#define RECVR_MAC {0x94, 0xB9, 0x7E, 0xD9, 0xDD, 0xD4}  // replace with your board's address
//#define BLINK_ON_SEND
//#define BLINK_ON_SEND_SUCCESS
#define BLINK_ON_RECV
#else
#define RECVR_MAC {0x94, 0xB9, 0x7E, 0xE4, 0x8D, 0xFC}  // replace with your board's address
//#define BLINK_ON_RECV
#endif
#define WIFI_CHAN  13 // 12-13 only legal in US in lower power mode, do not use 14
#define BAUD_RATE  115200
#define TX_PIN     1 // default UART0 is pin 1 (shared by USB)
#define RX_PIN     3 // default UART0 is pin 3 (shared by USB)
#define SER_PARAMS SERIAL_8N1 // SERIAL_8N1: start/stop bits, no parity
#define BUFFER_SIZE 250 // max of 250 bytes
//#define DEBUG // for additional serial messages (may interfere with other messages)
#ifndef LED_BUILTIN
#define LED_BUILTIN 2  // some boards don't have an LED or have it connected elsewhere
#endif
const uint8_t broadcastAddress[] = RECVR_MAC;
// wait for double the time between bytes at this serial baud rate before sending a packet
// this *should* allow for complete packet forming when using packetized serial comms
const uint32_t timeout_micros = (int)(1.0 / BAUD_RATE * 1E6) * 20;
uint8_t buf_recv[BUFFER_SIZE];
uint8_t buf_send[BUFFER_SIZE];
uint8_t buf_size = 0;
uint32_t send_timeout = 0;
esp_now_peer_info_t peerInfo;  // scope workaround for arduino-esp32 v2.0.1
#if defined(DEBUG) || defined(BLINK_ON_SEND_SUCCESS)
uint8_t led_status = 0;
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  #ifdef DEBUG
  if (status == ESP_NOW_SEND_SUCCESS) {
    Serial.println("Send success");
  } else {
  Serial.println("Send failed");
  #endif
  #ifdef BLINK_ON_SEND_SUCCESS
    led_status = ~led_status;
    // this function happens too fast to register a blink
    // instead, we latch on/off as data is successfully sent
    digitalWrite(LED_BUILTIN, led_status);
    return;
  // turn off the LED if send fails
  led_status = 0;
  #endif
#endif
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
  #ifdef BLINK_ON_RECV
  digitalWrite(LED_BUILTIN, HIGH);
  #endif
  memcpy(&amp;buf_recv, incomingData, sizeof(buf_recv));
  Serial.write(buf_recv, len);
  digitalWrite(LED_BUILTIN, LOW);
  #endif
  #ifdef DEBUG
  Serial.print("\n Bytes received: ");
  Serial.println(len);
  #endif
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.begin(BAUD_RATE, SER_PARAMS, RX_PIN, TX_PIN);
  Serial.println(send_timeout);
  WiFi.mode(WIFI_STA);
  #ifdef DEBUG
  Serial.print("ESP32 MAC Address: ");
  Serial.println(WiFi.macAddress());
  #endif
  if (esp_wifi_set_channel(WIFI_CHAN, WIFI_SECOND_CHAN_NONE) != ESP_OK) {
    #ifdef DEBUG
    Serial.println("Error changing WiFi channel");
    #endif
    return;
  if (esp_now_init() != ESP_OK) {
    #ifdef DEBUG
    Serial.println("Error initializing ESP-NOW");
    #endif
    return;
  esp_now_register_send_cb(OnDataSent);
  #endif
  // esp_now_peer_info_t peerInfo;  // scope workaround for arduino-esp32 v2.0.1
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = WIFI_CHAN;
  peerInfo.encrypt = false;
  if (esp_now_add_peer(&amp;peerInfo) != ESP_OK){
    #ifdef DEBUG
    Serial.println("Failed to add peer");
    #endif
    return;
  esp_now_register_recv_cb(OnDataRecv);
  // read up to BUFFER_SIZE from serial port
  if (Serial.available()) {
    while (Serial.available() &amp;&amp; buf_size &lt; BUFFER_SIZE) {
      buf_send[buf_size] = Serial.read();
      send_timeout = micros() + timeout_micros;
      buf_size++;
  // send buffer contents when full or timeout has elapsed
  if (buf_size == BUFFER_SIZE || (buf_size &gt; 0 &amp;&amp; micros() &gt;= send_timeout)) {
    #endif
    esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &amp;buf_send, buf_size);
    buf_size = 0;
    #ifdef DEBUG
    if (result == ESP_OK) {
      Serial.println("Sent!");
    else {
      Serial.println("Send error");
    #endif
    #endif
<p dir="auto">In the compilation i get this error, can someone help me?</p>
<pre><code>/private/var/folders/x9/48x6g6gs41n1h1yplgqqpvy00000gn/T/.arduinoIDE-unsaved2025728-672-1wfntf6.6pf8/ESP_NOW_Serial/ESP_NOW_Serial.ino: In function 'void setup()':
/private/var/folders/x9/48x6g6gs41n1h1yplgqqpvy00000gn/T/.arduinoIDE-unsaved2025728-672-1wfntf6.6pf8/ESP_NOW_Serial/ESP_NOW_Serial.ino:124:15: error: no matching function for call to 'HWCDC::begin(int, SerialConfig, int, int)'
  124 |   Serial.begin(BAUD_RATE, SER_PARAMS, RX_PIN, TX_PIN);
In file included from /Users/lb/Library/Arduino15/packages/esp32/hardware/esp32/3.3.0/cores/esp32/HardwareSerial.h:53,
                 from /Users/lb/Library/Arduino15/packages/esp32/hardware/esp32/3.3.0/cores/esp32/Arduino.h:202,
                 from /Users/lb/Library/Caches/arduino/sketches/F8F106E4318284D476156997E0306F8D/sketch/ESP_NOW_Serial.ino.cpp:1:
/Users/lb/Library/Arduino15/packages/esp32/hardware/esp32/3.3.0/cores/esp32/HWCDC.h:61:8: note: candidate: 'void HWCDC::begin(long unsigned int)'
   61 |   void begin(unsigned long baud = 0);
/Users/lb/Library/Arduino15/packages/esp32/hardware/esp32/3.3.0/cores/esp32/HWCDC.h:61:8: note:   candidate expects 1 argument, 4 provided
/private/var/folders/x9/48x6g6gs41n1h1yplgqqpvy00000gn/T/.arduinoIDE-unsaved2025728-672-1wfntf6.6pf8/ESP_NOW_Serial/ESP_NOW_Serial.ino:163:28: error: invalid conversion from 'void (*)(const uint8_t*, const uint8_t*, int)' {aka 'void (*)(const unsigned char*, const unsigned char*, int)'} to 'esp_now_recv_cb_t' {aka 'void (*)(const esp_now_recv_info*, const unsigned char*, int)'} [-fpermissive]
  163 |   esp_now_register_recv_cb(OnDataRecv);
      |                            void (*)(const uint8_t*, const uint8_t*, int) {aka void (*)(const unsigned char*, const unsigned char*, int)}
In file included from /private/var/folders/x9/48x6g6gs41n1h1yplgqqpvy00000gn/T/.arduinoIDE-unsaved2025728-672-1wfntf6.6pf8/ESP_NOW_Serial/ESP_NOW_Serial.ino:38:
/Users/lb/Library/Arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.5-b66b5448-v1/esp32s3/include/esp_wifi/include/esp_now.h:164:54: note:   initializing argument 1 of 'esp_err_t esp_now_register_recv_cb(esp_now_recv_cb_t)'
  164 | esp_err_t esp_now_register_recv_cb(esp_now_recv_cb_t cb);
exit status 1
Compilation error: no matching function for call to 'HWCDC::begin(int, SerialConfig, int, int)'
<p dir="auto">Thanks in advance</p>
]]></description><link>https://community.m5stack.com/topic/7789/esp-now-serial-bridge-on-m5atom-s3</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:09:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7789.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Aug 2025 10:51:12 GMT</pubDate><ttl>60</ttl></channel></rss>
