<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AtomS3R-CAM and telegram bot]]></title><description><![CDATA[<p dir="auto">Hi all, I would like to play with atom s3r cam to send photo on telegram ..</p>
<p dir="auto">this is the last not working code I try..</p>
#include &lt;WiFi.h&gt;
#include &lt;WiFiClientSecure.h&gt;
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "esp_camera.h"
#include &lt;UniversalTelegramBot.h&gt;
#include &lt;ArduinoJson.h&gt;
const char* ssid = "mywifi";
const char* password = "mywifipassword";
// Initialize Telegram BOT
String BOTtoken = "mybottoken";  // your Bot Token (Get from Botfather)
// Use @myidbot to find out the chat ID of an individual or a group
// Also note that you need to click "start" on a bot before it can
// message you
String CHAT_ID = "mychatid";
bool sendPhoto = false;
WiFiClientSecure clientTCP;
UniversalTelegramBot bot(BOTtoken, clientTCP);
#define FLASH_LED_PIN 4
bool flashState = LOW;
//Checks for new messages every 1 second.
int botRequestDelay = 1000;
unsigned long lastTimeBotRan;
//CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     -1
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      21
#define SIOD_GPIO_NUM     12
#define SIOC_GPIO_NUM     9
#define Y9_GPIO_NUM       13
#define Y8_GPIO_NUM       11
#define Y7_GPIO_NUM       17
#define Y6_GPIO_NUM       4
#define Y5_GPIO_NUM       48
#define Y4_GPIO_NUM       46
#define Y3_GPIO_NUM       42
#define Y2_GPIO_NUM        3
#define VSYNC_GPIO_NUM    10
#define HREF_GPIO_NUM     14
#define PCLK_GPIO_NUM     40
void configInitCamera(){
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_RGB565;
  //init with high specs to pre-allocate larger buffers
  if(psramFound()){
    config.frame_size = FRAMESIZE_QVGA;
    config.jpeg_quality = 12;  //0-63 lower number means higher quality
    config.fb_count = 2;
  } else {
  // camera init
  esp_err_t err = esp_camera_init(&amp;config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    delay(1000);
    ESP.restart();
  // Drop down frame size for higher initial frame rate
  sensor_t * s = esp_camera_sensor_get();
  s-&gt;set_framesize(s, FRAMESIZE_CIF);  // UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
void handleNewMessages(int numNewMessages) {
  Serial.print("Handle New Messages: ");
  Serial.println(numNewMessages);
  for (int i = 0; i &lt; numNewMessages; i++) {
    String chat_id = String(bot.messages[i].chat_id);
    if (chat_id != CHAT_ID){
      bot.sendMessage(chat_id, "Unauthorized user", "");
      continue;
    // Print the received message
    String text = bot.messages[i].text;
    Serial.println(text);
    String from_name = bot.messages[i].from_name;
    if (text == "/start") {
      String welcome = "Welcome , " + from_name + "\n";
      welcome += "Use the following commands to interact with the ESP32-CAM \n";
      welcome += "/photo : takes a new photo\n";
      welcome += "/flash : toggles flash LED \n";
      bot.sendMessage(CHAT_ID, welcome, "");
    if (text == "/flash") {
      flashState = !flashState;
      digitalWrite(FLASH_LED_PIN, flashState);
      Serial.println("Change flash LED state");
    if (text == "/photo") {
      sendPhoto = true;
            Serial.println("New photo request");
String sendPhotoTelegram() {
  const char* myDomain = "api.telegram.org";
  String getAll = "";
  String getBody = "";
  camera_fb_t * fb = NULL;
  fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("Camera capture failed");
    delay(1000);
    ESP.restart();
    return "Camera capture failed";
  Serial.println("Connect to " + String(myDomain));
  if (clientTCP.connect(myDomain, 443)) {
    Serial.println("Connection successful");
    String head = "--electroniclinic\r\nContent-Disposition: form-data; name=\"chat_id\"; \r\n\r\n" + CHAT_ID + "\r\n--electroniclinic\r\nContent-Disposition: form-data; name=\"photo\"; filename=\"esp32-cam.jpg\"\r\nContent-Type: image/jpeg\r\n\r\n";
    String tail = "\r\n--electroniclinic--\r\n";
    uint16_t imageLen = fb-&gt;len;
    uint16_t extraLen = head.length() + tail.length();
    uint16_t totalLen = imageLen + extraLen;
    clientTCP.println("POST /bot"+BOTtoken+"/sendPhoto HTTP/1.1");
    clientTCP.println("Host: " + String(myDomain));
    clientTCP.println("Content-Length: " + String(totalLen));
    clientTCP.println("Content-Type: multipart/form-data; boundary=electroniclinic");
    clientTCP.println();
    clientTCP.print(head);
    uint8_t *fbBuf = fb-&gt;buf;
    size_t fbLen = fb-&gt;len;
    for (size_t n=0;n&lt;fbLen;n=n+1024) {
      if (n+1024&lt;fbLen) {
        clientTCP.write(fbBuf, 1024);
        fbBuf += 1024;
      else if (fbLen%1024&gt;0) {
        size_t remainder = fbLen%1024;
        clientTCP.write(fbBuf, remainder);
    clientTCP.print(tail);
    esp_camera_fb_return(fb);
    int waitTime = 10000;   // timeout 10 seconds
    long startTimer = millis();
    boolean state = false;
    while ((startTimer + waitTime) &gt; millis()){
      Serial.print(".");
      delay(100);
      while (clientTCP.available()) {
        char c = clientTCP.read();
        if (state==true) getBody += String(c);
        if (c == '\n') {
          if (getAll.length()==0) state=true;
          getAll = "";
        else if (c != '\r')
          getAll += String(c);
      if (getBody.length()&gt;0) break;
    clientTCP.stop();
    Serial.println(getBody);
  else {
    getBody="Connected to api.telegram.org failed.";
    Serial.println("Connected to api.telegram.org failed.");
  return getBody;
void setup(){
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  // Init Serial Monitor
  Serial.begin(115200);
  // Set LED Flash as output
  pinMode(FLASH_LED_PIN, OUTPUT);
  // Config and init the camera
  configInitCamera();
  // Connect to Wi-Fi
  WiFi.mode(WIFI_STA);
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  clientTCP.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
  while (WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
    delay(500);
  Serial.println();
  Serial.print("ESP32-CAM IP Address: ");
  Serial.println(WiFi.localIP());
  if (sendPhoto) {
    Serial.println("Preparing photo");
    sendPhotoTelegram();
    sendPhoto = false;
  if (millis() &gt; lastTimeBotRan + botRequestDelay)  {
    int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
    while (numNewMessages) {
      Serial.println("got response");
      handleNewMessages(numNewMessages);
    lastTimeBotRan = millis();
<p dir="auto">I copied the camera pin and settings from the camera.ino example but atom craches after upload the code...</p>
<pre><code>ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0x3b (SPI_FAST_FLASH_BOOT)
Saved PC:0x40376bf2
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce2820,len:0x1150
load:0x403c8700,len:0x4
load:0x403c8704,len:0xc24
load:0x403cb700,len:0x30b4
entry 0x403c88b8
Build:Mar 27 2021
Saved PC:0x40376bf2
SPIWP:0xee
entry 0x403c88b8
<p dir="auto">some tips?</p>
<p dir="auto">best regards</p>
]]></description><link>https://community.m5stack.com/topic/7791/atoms3r-cam-and-telegram-bot</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:08:38 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7791.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Aug 2025 08:28:31 GMT</pubDate><ttl>60</ttl></channel></rss>
