<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unit MIDI: MIDI_IN to AUDIO_OUT?]]></title><description><![CDATA[<p dir="auto">I have unsuccesfully tried to get audio output from a midi keyboard in separate mode on the M5STACK Unit MID.</p>
<h2>My connection are as follows:</h2>
<li>Midi Keyboard → Unit MIDI MIDI_IN</li>
<li>Unit MIDI MIDI_OUT → USB MIDI adapter MIDI IN</li>
<li>Unit MIDI Audio OUT → 3.5 mm mini speaker</li>
<li>USB MIDI adapter USB → PC</li>
<li>PC → M5Stack ATOM type C</li>
<li>M5Stack ATOM groove → UNIT MIDI groove</li>
<p dir="auto">Midi UNIT is running micropython and a midi synth module which I translated from arduino to micropython.</p>
<h2>This is what I have tried:</h2>
<li>When in bypass mode, the keyboard sends events that can be caught by a midi usb device and forwarded to a PC.</li>
<li>The PC can send serial commands (via a M5 atom grove port) to the midi device and these are synthesized and played to audio out.</li>
<li>When in separate mode, no midi events are synthesized and played on the audio out.</li>
<h2>Questions</h2>
<p dir="auto">Is this a hardware limitation, or is it possible to configure midi in → audio out somehow to get sound without a controller connected to the groove port?</p>
<p dir="auto">Alternately, is it possible to catch the midi input events through the groove port and then forward these back to MIDI Unit to be synthesized to AUDIO_OUT?</p>
]]></description><link>https://community.m5stack.com/topic/7835/unit-midi-midi_in-to-audio_out</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 20:37:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7835.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Sep 2025 19:08:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unit MIDI: MIDI_IN to AUDIO_OUT? on Sun, 12 Oct 2025 18:44:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dov" aria-label="Profile: dov">@<bdi>dov</bdi></a> I think I ran in to the same thing if I understand your question.  See if this post helps.  It works for my situation</p>
<p dir="auto"><a href="https://community.m5stack.com/topic/7458/midi-synth-unit-with-din-trs-connectors-sam2695?_=1760294339690">https://community.m5stack.com/topic/7458/midi-synth-unit-with-din-trs-connectors-sam2695?_=1760294339690</a></p>
]]></description><link>https://community.m5stack.com/post/30056</link><guid isPermaLink="true">https://community.m5stack.com/post/30056</guid><dc:creator><![CDATA[earla]]></dc:creator><pubDate>Sun, 12 Oct 2025 18:44:02 GMT</pubDate></item></channel></rss>
