<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cannot delete &#x2F;replace python file in the filesystem]]></title><description><![CDATA[<p dir="auto">Hi , I'm creating a custom block to talk to Firebase database.<br />
I found that I need to upload my custom python file to the filesystem "lib" directory, in order for it to work<br />
But, If I try to make a correction or update the file, I delete it and upload  a new one, the old file still runs. it has not been deleted.<br />
Currently the workaround is to name the new file "<a href="http://filename2.py" target="_blank" rel="noopener noreferrer nofollow ugc">filename2.py</a>" instead of "<a href="http://filename.py" target="_blank" rel="noopener noreferrer nofollow ugc">filename.py</a>" and this works - the new file runs.<br />
The only way to completely revert to original mode is to wipe all the flash.<br />
Is there a fix for this issue?<br />
Using UIFLOW2 with StickCPlus1.1,  StickCplus2<br />
Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/7865/cannot-delete-replace-python-file-in-the-filesystem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:00:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7865.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Oct 2025 07:04:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cannot delete &#x2F;replace python file in the filesystem on Mon, 03 Nov 2025 11:39:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a> I wanted to create a simple flow for pupils that does not require more tools. it should be possible with the built in file manager, it seems like there is a bug , just wanted to know if there is a workaround</p>
]]></description><link>https://community.m5stack.com/post/30117</link><guid isPermaLink="true">https://community.m5stack.com/post/30117</guid><dc:creator><![CDATA[tom-test1]]></dc:creator><pubDate>Mon, 03 Nov 2025 11:39:20 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot delete &#x2F;replace python file in the filesystem on Mon, 27 Oct 2025 10:29:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom-test1" aria-label="Profile: tom-test1">@<bdi>tom-test1</bdi></a> have you tried to use "Thonny" to see and edit files?</p>
]]></description><link>https://community.m5stack.com/post/30090</link><guid isPermaLink="true">https://community.m5stack.com/post/30090</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 27 Oct 2025 10:29:00 GMT</pubDate></item></channel></rss>
