<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tab 5, how to enable Lora?]]></title><description><![CDATA[<p dir="auto">It appears that the tab5 is prepared to work with Lora.  Any idea how?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/7946/tab-5-how-to-enable-lora</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 19:48:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7946.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Dec 2025 20:47:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tab 5, how to enable Lora? on Sat, 20 Dec 2025 20:43:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/easytarget" aria-label="Profile: easytarget">@<bdi>easytarget</bdi></a> thank you. That is indeed an option.  In my experience not to much work to get a Lora module working.  We have a number of them in the field.  But we would like the tab5 not become thicker as it is.  We are now considering to place an Heltec Lora inside.  Maybe that could work.  Regards.</p>
]]></description><link>https://community.m5stack.com/post/30335</link><guid isPermaLink="true">https://community.m5stack.com/post/30335</guid><dc:creator><![CDATA[HappyUser]]></dc:creator><pubDate>Sat, 20 Dec 2025 20:43:56 GMT</pubDate></item><item><title><![CDATA[Reply to Tab 5, how to enable Lora? on Thu, 18 Dec 2025 14:01:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/happyuser" aria-label="Profile: HappyUser">@<bdi>HappyUser</bdi></a> The Tab5 also has a M-BUS interface (the big 30pin socket on the back) and mounting points for the m-bus modules.</p>
<p dir="auto">So; in theory you can 'just' plug in one of the modules from here: <a href="https://docs.m5stack.com/en/products?id=for%20stack-module" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/products?id=for stack-module</a></p>
<p dir="auto">But in practice it will probably need a bunch of work and understanding to get the pin assignments and drivers on the tab5 aligned and working.</p>
<li>There are other interesting M-BUS modules available (GPS, motor drive, prototype board, etc..)</li>
<li>The tab5 has the correct threaded mounting points to make the boards secure etc.</li>
]]></description><link>https://community.m5stack.com/post/30321</link><guid isPermaLink="true">https://community.m5stack.com/post/30321</guid><dc:creator><![CDATA[easytarget]]></dc:creator><pubDate>Thu, 18 Dec 2025 14:01:05 GMT</pubDate></item><item><title><![CDATA[Reply to Tab 5, how to enable Lora? on Wed, 17 Dec 2025 09:02:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thank you, that makes sense. Btw, a great product.</p>
]]></description><link>https://community.m5stack.com/post/30320</link><guid isPermaLink="true">https://community.m5stack.com/post/30320</guid><dc:creator><![CDATA[HappyUser]]></dc:creator><pubDate>Wed, 17 Dec 2025 09:02:42 GMT</pubDate></item><item><title><![CDATA[Reply to Tab 5, how to enable Lora? on Wed, 17 Dec 2025 07:56:57 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/happyuser" aria-label="Profile: HappyUser">@<bdi>HappyUser</bdi></a></p>
<p dir="auto">correct, M5Tab5 has an (empty) slot on its board which takes a stamp sized expansion like CatM or LoRa or ... - see backside picture of M5Tab5.</p>
<p dir="auto">That said, afaik at this point in time only the Stamp CatM exists. See <a href="https://docs.m5stack.com/en/products?id=for%20stamp-wireless" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">In other words, you'll need to wait until M5Stack releases a Stamp LoRa.</p>
]]></description><link>https://community.m5stack.com/post/30319</link><guid isPermaLink="true">https://community.m5stack.com/post/30319</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 17 Dec 2025 07:56:57 GMT</pubDate></item></channel></rss>
