<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[The LLM module AI-8850 reports itself as an AX650N?]]></title><description><![CDATA[<p dir="auto">When I query my AI-8850 module, it reports itself as an AX650N.</p>
<p dir="auto">Can someone provide more details on this?</p>
<pre><code>axcl-smi sh cat /proc/ax_proc/version -d 0
axcl-smi sh cat /proc/ax_proc/uid -d 0
axcl-smi sh cat /proc/ax_proc/board_id -d 0
Ax_Version V3.6.4_20250822020158
ax_uid: 0x600c301f4b65d204
AX650C_Demo
<pre><code class="language-[">[    4.971916] szProdName: AX650_card
[    4.979141] szFile: AX650_card.dtb
<p dir="auto">Is the AX8850 the same chipset?  Does it have the same performance?</p>
]]></description><link>https://community.m5stack.com/topic/7949/the-llm-module-ai-8850-reports-itself-as-an-ax650n</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 19:17:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7949.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Dec 2025 02:30:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to The LLM module AI-8850 reports itself as an AX650N? on Sun, 18 Jan 2026 06:12:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian111" aria-label="Profile: brian111">@<bdi>brian111</bdi></a> Both ax8850 and ax650n are not the identical SoC, but shares the same software stack. Make sure you use the ax650n documentation for development.</p>
]]></description><link>https://community.m5stack.com/post/30488</link><guid isPermaLink="true">https://community.m5stack.com/post/30488</guid><dc:creator><![CDATA[jonpark0]]></dc:creator><pubDate>Sun, 18 Jan 2026 06:12:48 GMT</pubDate></item><item><title><![CDATA[Reply to The LLM module AI-8850 reports itself as an AX650N? on Sat, 10 Jan 2026 21:57:31 GMT]]></title><description><![CDATA[<p dir="auto">Its not the same chipset but uses the same software. When I display my AX8850 it says AX650N. Did you get it to run with a model?</p>
]]></description><link>https://community.m5stack.com/post/30434</link><guid isPermaLink="true">https://community.m5stack.com/post/30434</guid><dc:creator><![CDATA[mpro77]]></dc:creator><pubDate>Sat, 10 Jan 2026 21:57:31 GMT</pubDate></item></channel></rss>
