<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Closed-Loop Stepper Motor Issue]]></title><description><![CDATA[<p dir="auto">I'm trying to connect a closed-loop stepper motor to a Duet 2 controller using an expansion board. Previously, I used a regular stepper motor with an external driver on the Duet.</p>
<p dir="auto">When I use the button to execute the jog (G0) command, the motor works fine. However, when I use other commands, such as homing (G1), the motor's movement becomes choppy and the distance is no longer accurate.</p>
<p dir="auto">The same result occurs if I trigger the closed loop using a switch.</p>
<p dir="auto">Strangely, the driver doesn't issue a missed step alarm. Therefore, it cannot detect missed steps. However,</p>
<p dir="auto">when I lock the motor, the driver alarms for missed steps.</p>
<p dir="auto">Motor and expansion board: [<a href="https://www.oyosteper.com/goods-587-1-axis-closed-looop-setper-cnc-kit-Series-12-NM-NEMA-23-Motor-Driver%20html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.oyosteper.com/goods-587-1-axis-closed-looop-setper-cnc-kit-Series-12-NM-NEMA-23-Motor-Driver html</a>]. Has anyone encountered this situation? Or is there any solution?</p>
]]></description><link>https://community.m5stack.com/topic/7953/closed-loop-stepper-motor-issue</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 18:15:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7953.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Dec 2025 07:04:21 GMT</pubDate><ttl>60</ttl></channel></rss>
