<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Optimized Realistic Vision stable diffusion model for use with AI-8850 LLM Acceleration M.2 Module (AX8850) available on HF]]></title><description><![CDATA[<p dir="auto">I have optimized the Realistic Vision stable diffusion model for use with AI-8850 LLM Acceleration M.2 Module (AX8850):</p>
<p dir="auto"><a href="https://huggingface.co/gregm123456/realistic-vision-v6-axera-hw" target="_blank" rel="noopener noreferrer nofollow ugc">https://huggingface.co/gregm123456/realistic-vision-v6-axera-hw</a></p>
<p dir="auto">Realistic Vision is optimized for more general photorealism, and this optimized vesion can be used in place of the model that was chosen for this example:</p>
<p dir="auto"><a href="https://github.com/AXERA-TECH/sd1.5-lcm.axera" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/AXERA-TECH/sd1.5-lcm.axera</a></p>
]]></description><link>https://community.m5stack.com/topic/7965/optimized-realistic-vision-stable-diffusion-model-for-use-with-ai-8850-llm-acceleration-m-2-module-ax8850-available-on-hf</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:12:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7965.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Dec 2025 22:40:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Optimized Realistic Vision stable diffusion model for use with AI-8850 LLM Acceleration M.2 Module (AX8850) available on HF on Sun, 01 Feb 2026 18:45:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/seahope" aria-label="Profile: seahope">@<bdi>seahope</bdi></a> Interesting post! Leveraging HF models like Realistic Vision with the AX8850 module sounds like a solid step toward faster, more efficient on-device AI workflows.</p>
]]></description><link>https://community.m5stack.com/post/30553</link><guid isPermaLink="true">https://community.m5stack.com/post/30553</guid><dc:creator><![CDATA[wayner.d]]></dc:creator><pubDate>Sun, 01 Feb 2026 18:45:53 GMT</pubDate></item><item><title><![CDATA[Reply to Optimized Realistic Vision stable diffusion model for use with AI-8850 LLM Acceleration M.2 Module (AX8850) available on HF on Sun, 25 Jan 2026 13:54:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gregm123456" aria-label="Profile: gregm123456">@<bdi>gregm123456</bdi></a> HI. I don't suppose you know how to ask the driver developers about bugs? I am getting a lot of this:<br />
67% | ██████████████████████            |  21 /  31 [20.57s&lt;30.37s, 1.02 count/s] init 11 axmodel ok,devid(0) remain_cmm(3954 MB)[2026-01-25 14:53:12.889][3991][E][engine][invoke][97]: Decode api(4) response failed.<br />
[E][                            init][ 421]: AX_ENGINE_CreateHandle<br />
70% | ███████████████████████           |  22 /  31 [21.09s&lt;29.71s, 1.04 count/s] init 4 axmodel ok,devid(0) remain_cmm(4014 MB)[2026-01-25 14:53:14.038][3991][E][engine][invoke][97]: Decode api(4) response failed.<br />
74% | ████████████████████████          |  23 /  31 [22.57s&lt;30.42s, 1.02 count/s] init 19 axmodel ok,devid(0) remain_cmm(3825 MB)[2026-01-25 14:53:14.843][3991][E][engine][invoke][97]: Decode api(4) response failed.<br />
77% | █████████████████████████         |  24 /  31 [23.04s&lt;29.76s, 1.04 count/s] init 26 axmodel ok,devid(0) remain_cmm(3885 MB)[2026-01-25 14:53:15.992][3991][E][engine][invoke][97]: Decode api(4) response failed.<br />
80% | ██████████████████████████        |  25 /  31 [24.57s&lt;30.47s, 1.02 count/s] init 12 axmodel ok,devid(0) remain_cmm(3696 MB)[2026-01-25 14:53:16.796][3991][E][engine][invoke][97]: Decode api(4) response failed.<br />
83% | ███████████████████████████       |  26 /  31 [25.00s&lt;29.80s, 1.04 count/s] init 5 axmodel ok,devid(0) remain_cmm(3756 MB)[2026-01-25 14:53:17.945][3991][E][engine][invoke][97]: Decode api(4) response failed.<br />
87% | ████████████████████████████      |  27 /  31 [26.57s&lt;30.51s, 1.02 count/s] init 20 axmodel ok,devid(0) remain_cmm(3567 MB)[2026-01-25 14:53:18.751][3991][E][engine][invoke][97]: Decode api(4) response failed.<br />
90% | █████████████████████████████     |  28 /  31 [26.95s&lt;29.84s, 1.04 count/s] init 27 axmodel ok,devid(0) remain_cmm(3627 MB)[E][                            init][ 421]: AX_ENGINE_CreateHandle<br />
[2026-01-25 14:53:19.897][3991][E][engine][invoke][97]: Decode api(4) response failed.<br />
[2026-01-25 14:53:20.654][3991][E][engine][invoke][97]: Decode api(4) response failed.<br />
93% | ██████████████████████████████    |  29 /  31 [28.53s&lt;30.49s, 1.02 count/s] init 6 axmodel ok,devid(0) rema 96% | ███████████████████████████████   |  30 /  31 [28.54s&lt;29.49s, 1.05 count/s] init 13 axmodel ok,devid(0) rem100% | ████████████████████████████████ |  31 /  31 [34.14s&lt;34.14s, 0.91 count/s] init post axmodel ok,remain_cmm(3302 MB)Working directory: /home/stevef/dev/Qwen3-1.7B<br />
Starting tokenizer server on port 12300...<br />
Server running on port 12300<br />
Starting main API application...<br />
[I][                            Init][ 130]: LLM init start<br />
[I][                            Init][  34]: connect <a href="http://127.0.0.1:12300" target="_blank" rel="noopener noreferrer nofollow ugc">http://127.0.0.1:12300</a> ok<br />
[I][                            Init][  57]: uid: cacc4142-cf79-4f83-b257-4a4cd94707bb<br />
bos_id: 151643, eos_id: 151645<br />
3% | ██                                |   1 /  31 [0.88s&lt;27.19s, 1.14 count/s] tokenizer init ok[I][                            Init][  45]: LLaMaEmbedSelector use mmap<br />
6% | ███                               |   2 /  31 [0.88s&lt;13.59s, 2.28 count/s] embed_selector init ok<br />
[I][                             run][  30]: AXCLWorker start with devid 0<br />
[2026-01-25 14:53:47.641][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
[2026-01-25 14:53:48.398][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
9% | ████                              |   3 /  31 [3.57s&lt;36.87s, 0.84 count/s] init 0 axmodel ok,devid(0) remai 12% | █████                             |   4 /  31 [3.87s&lt;29.96s, 1.03 count/s] init 7 axmodel ok,devid(0) remain_cmm(5117 MB)[2026-01-25 14:53:49.159][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
16% | ██████                            |   5 /  31 [4.87s&lt;30.19s, 1.03 count/s] init 21 axmodel ok,devid(0) remain_cmm(5117 MB)[2026-01-25 14:53:49.963][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
19% | ███████                           |   6 /  31 [5.46s&lt;28.20s, 1.10 count/s] init 14 axmodel ok,devid(0) remain_cmm(4983 MB)[2026-01-25 14:53:51.308][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
22% | ████████                          |   7 /  31 [6.87s&lt;30.43s, 1.02 count/s] init 1 axmodel ok,devid(0) remain_cmm(4859 MB)[2026-01-25 14:53:52.113][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
25% | █████████                         |   8 /  31 [7.87s&lt;30.50s, 1.02 count/s] init 8 axmodel ok,devid(0) remain_cmm(4859 MB)[E][                            init][ 421]: AX_ENGINE_CreateHandle<br />
[2026-01-25 14:53:52.917][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
[2026-01-25 14:53:53.870][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
29% | ██████████                        |   9 /  31 [9.04s&lt;31.14s, 1.00 count/s] init 15 axmodel ok,devid(0) rema 32% | ███████████                       |  10 /  31 [9.06s&lt;28.08s, 1.10 count/s] init 22 axmodel ok,devid(0) remain_cmm(4789 MB)[E][                            init][ 421]: AX_ENGINE_CreateHandle<br />
[2026-01-25 14:53:55.025][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
35% | ████████████                      |  11 /  31 [10.87s&lt;30.64s, 1.01 count/s] init 2 axmodel ok,devid(0) remain_cmm(4600 MB)[2026-01-25 14:53:55.829][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
38% | █████████████                     |  12 /  31 [11.32s&lt;29.25s, 1.06 count/s] init 9 axmodel ok,devid(0) remain_cmm(4660 MB)[2026-01-25 14:53:56.977][4245][E][engine][invoke][97]: Decode api(4) response failed.<br />
[E][                            init][ 421]: AX_ENGINE_Cr</p>
<p dir="auto">Infinite loop only solved by a reboot</p>
]]></description><link>https://community.m5stack.com/post/30516</link><guid isPermaLink="true">https://community.m5stack.com/post/30516</guid><dc:creator><![CDATA[seahope]]></dc:creator><pubDate>Sun, 25 Jan 2026 13:54:41 GMT</pubDate></item></channel></rss>
