<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5burner issue Arch Linux]]></title><description><![CDATA[<p dir="auto">I'm experiencing multiple issues uploading firmware to the cardputer.<br />
I'm unable to connect to the cardputer unless I do: "sudo chown 'user' ttyACM0"<br />
After do this I can verify a connection in m5burner but I can't burn anything if I do it  says the following:</p>
<p dir="auto">"JavaScript error occurred in the main process"<br />
"uncaught Exception:<br />
Error: spawn /mnt/'drive'/'file'/0M5Burner-v3-beta-linux-x64/packages/tool/esptool EACCES<br />
at Process.ChildProcess._handle.onexit (node:internal/child_process:282:19<br />
at onErrorNT (node:internal/child_process:477:16)<br />
at processTicksAndRejections (node:internal/process/task_queues:83:21</p>
<p dir="auto">I've also tried running as admin.<br />
"sudo ./m5burner"<br />
which returns:<br />
[1230/051906.244212:FATAL:electron_main_delegate.cc(290)] Running as root without --no-sandbox is not supported. See <a href="https://crbug.com/638180" target="_blank" rel="noopener noreferrer nofollow ugc">https://crbug.com/638180</a>.<br />
fish: Job 1, 'sudo ./m5burner' terminated by signal SIGTRAP (Trace or breakpoint trap)</p>
<p dir="auto">so then I tried adding no sandbox "sudo --no--sandbox ./m5burner"<br />
which returns<br />
sudo: unrecognized option '--no--sandbox'</p>
<p dir="auto">I welcome any suggestions that might fix this sour pickle.</p>
]]></description><link>https://community.m5stack.com/topic/7978/m5burner-issue-arch-linux</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:45:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7978.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Dec 2025 13:31:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5burner issue Arch Linux on Sun, 11 Jan 2026 14:44:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kumohoshi42" aria-label="Profile: kumohoshi42">@<bdi>kumohoshi42</bdi></a><br />
Thanks for sharing how you resolved the problem!</p>
]]></description><link>https://community.m5stack.com/post/30436</link><guid isPermaLink="true">https://community.m5stack.com/post/30436</guid><dc:creator><![CDATA[bschwahn]]></dc:creator><pubDate>Sun, 11 Jan 2026 14:44:00 GMT</pubDate></item><item><title><![CDATA[Reply to M5burner issue Arch Linux on Sun, 11 Jan 2026 11:17:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kumohoshi42" aria-label="Profile: kumohoshi42">@<bdi>kumohoshi42</bdi></a> I solved this if anyone from Arch or any arch based distro.<br />
The Java exception was created because my user doesn't have permission to make a folder in /mnt.<br />
To fix this I used bash to create a folder called "drive" and then I could make a folder in that called "folder".<br />
Then for safety I copied the m5burner folder to there and that's where I'm gonna burn from.</p>
<p dir="auto">I hope this helps any future Arch users &lt;3 &lt;3</p>
]]></description><link>https://community.m5stack.com/post/30435</link><guid isPermaLink="true">https://community.m5stack.com/post/30435</guid><dc:creator><![CDATA[kumohoshi42]]></dc:creator><pubDate>Sun, 11 Jan 2026 11:17:34 GMT</pubDate></item></channel></rss>
