<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ENV Monitor ADV]]></title><description><![CDATA[<p dir="auto">ENV Monitor ADV (M5Cardputer)</p>
<p dir="auto">ENV Monitor ADV is an environmental monitoring app for M5Stack Cardputer ADV (ESP32-S3).<br />
It reads live sensor data from BME280 (temperature, humidity, pressure) and VEML7700 (ambient light / lux), displays it on the device with a smooth no-flicker UI, and can log measurements to an SD card as a CSV file. It also includes built-in Wi-Fi (STA or AP) and a lightweight web dashboard for live readings, a dynamic chart, and CSV download.</p>
<p dir="auto">Features<br />
Live monitoring (no flicker)<br />
Real-time display: Lux / Temperature / Humidity / Pressure<br />
Screen layout stays stable; only values update (comfortable to watch)<br />
Bottom status bar shows SD / LOG / Wi-Fi state + IP<br />
CSV logging to SD<br />
Logging mode writes simple CSV compatible with Excel<br />
File: /env_log.csv<br />
Columns: lux;temp_c;hum_pct;press_hpa;time_s<br />
Configurable refresh + log interval via SD config file<br />
Graphs on the device<br />
Draw a chart directly on the Cardputer from the saved log<br />
Select parameter (Lux/Temp/Hum/Press) and number of points<br />
Auto scaling (min/max + margin) + axes<br />
Wi-Fi + Web Dashboard</p>
<p dir="auto">STA mode: scan networks → select SSID → enter password → connect<br />
(credentials are saved to SD for next reboot)<br />
AP mode: create a hotspot for direct phone/laptop connection</p>
<p dir="auto">Web UI provides:<br />
Live values<br />
Dynamic chart (auto scale)<br />
One-click CSV download<br />
Screen saver (burn-in protection)<br />
Select timeout (30/60/120/150/180 seconds)<br />
Screen dims off, wakes instantly on key activity<br />
Theme colors<br />
Multiple UI accent themes (device + web page styling)<br />
Hardware / Sensors<br />
Device: M5Stack Cardputer ADV</p>
<p dir="auto">Sensors (I²C):</p>
<p dir="auto">BME280 (Temp/Hum/Pressure) — typical address 0x76/0x77<br />
VEML7700 (Lux) — address 0x10</p>
<p dir="auto">SD Card Files<br />
/env_cfg.txt — app settings (refresh, log interval, separator, timeout, theme)<br />
/wifi_cfg.txt — saved Wi-Fi credentials (plaintext)<br />
/env_log.csv — measurement log</p>
<p dir="auto">Web Endpoints (for advanced use)<br />
/ — Web dashboard<br />
/api/live — JSON live readings<br />
/api/history — JSON history buffer (chart)<br />
/api/info — Wi-Fi status + IP<br />
/api/log.csv — CSV log download</p>
<p dir="auto">I'd be grateful for your tests and feedback. If anyone wants, I can add a wiring diagram.</p>
<p dir="auto"><a href="https://m5burner-cdn.m5stack.com/firmware/7817e624bcd16dd4dc7bd826506876b7.bin" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5burner-cdn.m5stack.com/firmware/7817e624bcd16dd4dc7bd826506876b7.bin</a></p>
]]></description><link>https://community.m5stack.com/topic/8022/env-monitor-adv</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:08:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8022.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Jan 2026 19:14:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ENV Monitor ADV on Sat, 07 Feb 2026 05:56:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi, <a class="plugin-mentions-user plugin-mentions-a" href="/user/aliense44" aria-label="Profile: aliense44">@<bdi>aliense44</bdi></a>. I have a Card Computer ADV, a GPS/LoRa module, and an ENV III Sensor. I was trying to test the ENV Monitor ADV app, but it didn't display any information. Could you tell me how to connect it for it to work with the app? Thank you.</p>
]]></description><link>https://community.m5stack.com/post/30607</link><guid isPermaLink="true">https://community.m5stack.com/post/30607</guid><dc:creator><![CDATA[nunoluna]]></dc:creator><pubDate>Sat, 07 Feb 2026 05:56:00 GMT</pubDate></item></channel></rss>
