<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help needed: M5Stack Dial VFD controller (relay start&#x2F;stop + 0–10V speed)]]></title><description><![CDATA[<p dir="auto">Hey everyone — I’m building a VFD controller using an M5Stack Dial (ESP32-S3) and I’m looking for help/advice from anyone who’s done something similar.</p>
<p dir="auto">Goal:</p>
<p dir="auto">Use the Dial screen/knob UI to control VFD speed via 0–10V</p>
<p dir="auto">Use a relay output for Run/Stop (or FWD/REV if possible)</p>
<p dir="auto">Clean, reliable wiring and code (industrial-ish setup)</p>
<p dir="auto">Hardware I’m using / planning:</p>
<p dir="auto">M5Stack Dial (ESP32-S3)</p>
<p dir="auto">External 0–10V output module (DAC module or converter board)</p>
<p dir="auto">Relay module / isolated output to drive VFD digital input(s)</p>
<p dir="auto">Common 24V control cabinet environment (if needed)</p>
<p dir="auto">What I need help with:</p>
<p dir="auto">Best/most reliable way to generate 0–10V from ESP32 (recommended module/wiring)</p>
<p dir="auto">Proper isolation/grounding between ESP32, DAC, and VFD analog input</p>
<p dir="auto">Example code (Arduino or MicroPython) for knob → voltage output + button/relay logic</p>
<p dir="auto">UI ideas for the Dial (speed %, Hz, RPM, presets, accel/decel)</p>
<p dir="auto">If anyone has a wiring diagram, known-good DAC module, sample code, or tips, I’d really appreciate it!</p>
]]></description><link>https://community.m5stack.com/topic/8060/help-needed-m5stack-dial-vfd-controller-relay-start-stop-0-10v-speed</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 18:15:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8060.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Feb 2026 14:19:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help needed: M5Stack Dial VFD controller (relay start&#x2F;stop + 0–10V speed) on Thu, 05 Feb 2026 08:59:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gizmologic" aria-label="Profile: gizmologic">@<bdi>gizmologic</bdi></a> so in short words what you need is convert m5dial encoder to 0-10v signal and operate exernal relay with screen button right? what is your code so far?</p>
]]></description><link>https://community.m5stack.com/post/30586</link><guid isPermaLink="true">https://community.m5stack.com/post/30586</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Thu, 05 Feb 2026 08:59:22 GMT</pubDate></item></channel></rss>
