<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Internal pull-up support on Unit PbHub &#x2F; Unit EXT.IO2?]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I am using Unit PbHub and would like to ask about internal pull-up resistors.<br />
The STM32F030 used in PbHub and EXT.IO2 supports internal pull-up/pull-down at the hardware level, but I could not find any way to enable pull-ups using the current M5Stack libraries. There seems to be no API to configure pull modes.<br />
Is it currently possible to enable internal pull-up resistors on PbHub or EXT.IO2?<br />
If not, is firmware modification the only option, or are there plans to support this in the future?<br />
I would appreciate any official clarification or recommended workaround.<br />
Thank you.</p>
]]></description><link>https://community.m5stack.com/topic/8062/internal-pull-up-support-on-unit-pbhub-unit-ext-io2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:45:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8062.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Feb 2026 12:51:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Internal pull-up support on Unit PbHub &#x2F; Unit EXT.IO2? on Thu, 05 Feb 2026 19:55:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
Thank you for the clarification.<br />
Yes, it seems that internal pull-up/pull-down resistors cannot be controlled at the moment.<br />
I also checked the documentation, but could not find any way to configure this, which is why I posted the question here.</p>
<p dir="auto">I hope this feature can be supported in the future, as it would be very useful in practice.</p>
<p dir="auto">Thanks again for sharing your experience.</p>
]]></description><link>https://community.m5stack.com/post/30596</link><guid isPermaLink="true">https://community.m5stack.com/post/30596</guid><dc:creator><![CDATA[sk-ys]]></dc:creator><pubDate>Thu, 05 Feb 2026 19:55:22 GMT</pubDate></item><item><title><![CDATA[Reply to Internal pull-up support on Unit PbHub &#x2F; Unit EXT.IO2? on Thu, 05 Feb 2026 15:21:37 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/sk-ys" aria-label="Profile: sk-ys">@<bdi>sk-ys</bdi></a></p>
<p dir="auto">currently PbHub does <strong>not</strong> support internal pull-up/pull-down resistors. See FAQ at the end of the documentation page <a href="https://docs.m5stack.com/en/unit/pbhub_1.1" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>. I assume the same is true for EXT.IO2.</p>
<p dir="auto">Note: I have no idea if there are plans to support this feature in the future.</p>
<p dir="auto">BTW: I faced the same issue a while ago and I resorted to adding some 10 k SMD resistors to the inputs.</p>
]]></description><link>https://community.m5stack.com/post/30595</link><guid isPermaLink="true">https://community.m5stack.com/post/30595</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 05 Feb 2026 15:21:37 GMT</pubDate></item></channel></rss>
