<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Charge battery Module (13.2 or M002) from Base26 (or else, not USB-C)]]></title><description><![CDATA[<p dir="auto">Hello all,<br />
I have a CoreS3-SE (no internal battery), a Battery Module M002 (same bus connections as the 13.2) and a Base26 with power input barrel connector  9-24V.<br />
I'd like to charge the battery when the sytem is powered from the Base26 connector (and not from the USB-C), possibly by doing some internal modification or an additional circuit. I have the whole Base26 customizable PCB for that. I'd prefer not to use the USB-C port.<br />
The battery module should act as a kind of "UPS" for the system.<br />
What's the best/most reliable way to do that?<br />
Could the 4 pin connector on the back of the CoreS3 module, just over the USB-C port, be a good way to connect the +5V from the Base module? Seems a USB connector (D+ and D-) and, from schematics and indication on the back plane shield, should be a good place for GND VUSB (in practice identical to the USB-C port).</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://community.m5stack.com/topic/8064/charge-battery-module-13-2-or-m002-from-base26-or-else-not-usb-c</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 11:55:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8064.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Feb 2026 11:12:21 GMT</pubDate><ttl>60</ttl></channel></rss>
