<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to mount M5stack modules to a metal plate]]></title><description><![CDATA[<p dir="auto">Hello,<br />
In my project, I’m using several M5Stack modules:</p>
<li>ATOMIC PoE Base W5500 with Atom S3 Lite</li>
<li>Extend I/O 2 Unit (STM32F0)</li>
<li>1 to 3 HUB Expansion U006</li>
<li>Unit RFID2 SKU: U031-B</li>
<p dir="auto">I’ve noticed that all of these modules feature 5mm diameter holes. Are these intended to serve as clearance holes for screws?</p>
<p dir="auto">Additionally, how should I attach the ATOMIC PoE Base W5500 with the Atom S3 Lite if the two 5mm diameter holes will be obstructed by the Atom S3 Lite?</p>
]]></description><link>https://community.m5stack.com/topic/8075/how-to-mount-m5stack-modules-to-a-metal-plate</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 06:21:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8075.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Feb 2026 08:46:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to mount M5stack modules to a metal plate on Tue, 10 Feb 2026 12:00:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/galehill" aria-label="Profile: galehill">@<bdi>galehill</bdi></a> The "5mm" holes, actually 4.85mm, are for Lego pegs to attach the Atomic base to Lego Technic parts like beams. Most M5stack things have Lego-compatible mounting points.<br />
If you look under the Atom Lite, there's a small yellow M2 hole marked on the label which you can use to fix the atom to the atomic base from below. There's a M2-sized hole in the atomic base. Just screw through the atomic base from below, into the atom label and there's a thread inside.<br />
M5stack used to supply a M2 hex-headed bolt of the correct length and a little Allen key to mount the atom on the base.<br />
But usually just mounting the atom on the atomic base pins is enough for most uses.</p>
]]></description><link>https://community.m5stack.com/post/30622</link><guid isPermaLink="true">https://community.m5stack.com/post/30622</guid><dc:creator><![CDATA[veryalien]]></dc:creator><pubDate>Tue, 10 Feb 2026 12:00:52 GMT</pubDate></item></channel></rss>
