<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issue with m5dial and Unit 4Relay]]></title><description><![CDATA[<p dir="auto">Hello I have m5dial and connected to port A Unit 4Relay<br />
When I download program to m5dial with Unit 4Relay its works okay, but sometimes when relay turn (no matter what) I get this error in m5dial<br />
<img src="/assets/uploads/files/1770801673755-img_9125.jpeg" alt="IMG_9125.JPEG" class=" img-fluid img-markdown" /></p>
<p dir="auto">When I burn m5dial to V 2.4.2i get this error(5x per hour) so it was worst then V 2.3.6  (1x per day)</p>
<p dir="auto">Can someone help me with this pls?</p>
]]></description><link>https://community.m5stack.com/topic/8077/issue-with-m5dial-and-unit-4relay</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:35:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8077.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Feb 2026 09:24:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issue with m5dial and Unit 4Relay on Wed, 11 Feb 2026 10:05:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a> Yes it happens only when relay is called to be on not in standby<br />
Unit 4relay is connected to Port A with his supply(5V), but I using +24vdc for supplied m5dial</p>
]]></description><link>https://community.m5stack.com/post/30627</link><guid isPermaLink="true">https://community.m5stack.com/post/30627</guid><dc:creator><![CDATA[PPKOVY]]></dc:creator><pubDate>Wed, 11 Feb 2026 10:05:23 GMT</pubDate></item><item><title><![CDATA[Reply to Issue with m5dial and Unit 4Relay on Wed, 11 Feb 2026 10:00:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ppkovy" aria-label="Profile: PPKOVY">@<bdi>PPKOVY</bdi></a> it happens only when relay is called to be on? or on "standby" too?<br />
is your unit 4relay supplied from external voltage source?</p>
]]></description><link>https://community.m5stack.com/post/30626</link><guid isPermaLink="true">https://community.m5stack.com/post/30626</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Wed, 11 Feb 2026 10:00:11 GMT</pubDate></item></channel></rss>
