<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[OSError: [Errno 1] EPERM: ESP_FAIL M5Stack CoreS3 + Unit CamS3 displaying image on m5Stack]]></title><description><![CDATA[<p dir="auto">Hey,<br />
I just starting my journey with M5stack, entering with very little knowledge about programming, I'm mostly supporting myself with AI language models who write scripts for me. I find it pretty interesting way to learn. At some point however I got stuck and I need your help.<br />
I want simple thing - to display image from Unit CamS3 camera on M5Stack CoreS3 screen.<br />
I tried already about 100 different scripts and all of them are ending with the same error:<br />
OSError: [Errno 1] EPERM: ESP_FAIL</p>
<p dir="auto">I use Thonny and M5Burner.</p>
<p dir="auto">Any help really appreciated.<br />
Thank you</p>
]]></description><link>https://community.m5stack.com/topic/8083/oserror-errno-1-eperm-esp_fail-m5stack-cores3-unit-cams3-displaying-image-on-m5stack</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:55:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8083.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Feb 2026 14:15:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to OSError: [Errno 1] EPERM: ESP_FAIL M5Stack CoreS3 + Unit CamS3 displaying image on m5Stack on Mon, 16 Feb 2026 22:10:24 GMT]]></title><description><![CDATA[<p dir="auto">Hi! Thanks to both of you for your answers.</p>
<p dir="auto">I managed to get it working by using a different approach-via Wi-Fi. However, I’m still curious: why couldn't I connect via UART?</p>
<p dir="auto">I suspect it might be related to the camera's firmware. It seems like the Unit CamS3 5MP Wi-Fi doesn't have default firmware to stream JPEG over UART. Is that correct? I’d love to understand why it works over Wi-Fi but fails over UART. I either managed to connect with camera (pin 17 and 18) but couldn't get any data back.<br />
Any insights would be greatly appreciated!</p>
]]></description><link>https://community.m5stack.com/post/30650</link><guid isPermaLink="true">https://community.m5stack.com/post/30650</guid><dc:creator><![CDATA[katastrofiko]]></dc:creator><pubDate>Mon, 16 Feb 2026 22:10:24 GMT</pubDate></item><item><title><![CDATA[Reply to OSError: [Errno 1] EPERM: ESP_FAIL M5Stack CoreS3 + Unit CamS3 displaying image on m5Stack on Mon, 16 Feb 2026 06:53:18 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/katastrofiko" aria-label="Profile: katastrofiko">@<bdi>katastrofiko</bdi></a></p>
<p dir="auto">may I suggest that you - as a beginner - try something simpler to start with? Displaying an image from Unit CamS3 camera on M5Stack CoreS3 screen is not exactly a simple thing.</p>
<p dir="auto">However if you insist on doing that then I suggest you feed the error message into your AI and let AI fix it. Or try the next 100 scripts AI spits out. (Edison ultimately had success too.)</p>
<p dir="auto">Personal side note: As a human being and software engineer I am glad that AI was not (yet) able to figure it out. That gives me hope for mankind.</p>
]]></description><link>https://community.m5stack.com/post/30645</link><guid isPermaLink="true">https://community.m5stack.com/post/30645</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 16 Feb 2026 06:53:18 GMT</pubDate></item><item><title><![CDATA[Reply to OSError: [Errno 1] EPERM: ESP_FAIL M5Stack CoreS3 + Unit CamS3 displaying image on m5Stack on Mon, 16 Feb 2026 01:11:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/katastrofiko" aria-label="Profile: katastrofiko">@<bdi>katastrofiko</bdi></a></p>
<p dir="auto">Hi, I have a S3 but I haven't focused on the Camera aspect yet as I am trying to get another project done with what little free time I have. There usually are examples in UIFLOW that you can download but I didn't see any right away.</p>
<p dir="auto">I did find a PDF files that does have some basic samples using UIFLOW which brings me to my next point...being an educator there are limits on what one can use/learn AI for. I would encourage you to use UIFLOW first for proof of concept and then begin reverse engineer the micro python code that UIFLOW creates.</p>
<p dir="auto"><a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/products/core/CoreS3/CoreS3%20Development%20Kit-compressed%20(1).pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/products/core/CoreS3/CoreS3 Development Kit-compressed (1).pdf</a></p>
<p dir="auto">Good luck and when it works be sure to post the code here!</p>
]]></description><link>https://community.m5stack.com/post/30644</link><guid isPermaLink="true">https://community.m5stack.com/post/30644</guid><dc:creator><![CDATA[bschwahn]]></dc:creator><pubDate>Mon, 16 Feb 2026 01:11:24 GMT</pubDate></item></channel></rss>
