<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issue with unit 4 relay on cores3]]></title><description><![CDATA[<p dir="auto">Hello, I have a unit 4-relay, which works when connected to an atom-lite, but not when connected to a cores3 (SE lite)</p>
<p dir="auto">Here is the config for the cores3 and atom-lite.</p>
<p dir="auto">On the cores3 (module connected through port A), I see no devices found on i2c scan. It finds OK on the atom-lite</p>
<pre><code>[17:35:54.929][C][i2c.idf:093]: I2C Bus:
[17:35:54.932][C][i2c.idf:094]:   SDA Pin: GPIO2
[17:35:54.932][C][i2c.idf:094]:   SCL Pin: GPIO1
[17:35:54.932][C][i2c.idf:094]:   Frequency: 50000 Hz
[17:35:54.935][C][i2c.idf:104]:   Recovery: bus successfully recovered
[17:35:54.935][C][i2c.idf:114]: Results from bus scan:
[17:35:54.939][C][i2c.idf:116]: Found no devices
[17:35:54.940][C][unit4relay:028]:   Address: 0x26
[17:35:54.940][C][unit4relay:030]: Switch:
[17:35:54.945][C][unit4relay:092]:   Relay 1 'Base Relay Channel 1'
[17:35:54.945][C][unit4relay:092]:     Restore Mode: restore defaults to OFF
[17:35:54.946][C][unit4relay:157]:     Icon: 'mdi:flash'
[17:35:54.946][C][unit4relay:163]:     Device Class: 'switch'
[17:35:54.950][C][unit4relay:092]:   Relay 2 'Base Relay Channel 2'
[17:35:54.950][C][unit4relay:092]:     Restore Mode: restore defaults to OFF
[17:35:54.952][C][unit4relay:157]:     Icon: 'mdi:flash'
[17:35:54.952][C][unit4relay:163]:     Device Class: 'switch'
[17:35:54.959][C][unit4relay:092]:   Relay 3 'Base Relay Channel 3'
[17:35:54.959][C][unit4relay:092]:     Restore Mode: restore defaults to OFF
[17:35:54.960][C][unit4relay:157]:     Icon: 'mdi:flash'
[17:35:54.960][C][unit4relay:163]:     Device Class: 'switch'
[17:35:54.963][C][unit4relay:092]:   Relay 4 'Relay Channel 4'
[17:35:54.963][C][unit4relay:092]:     Restore Mode: restore defaults to OFF
[17:35:54.963][C][unit4relay:157]:     Icon: 'mdi:flash'
[17:35:54.963][C][unit4relay:163]:     Device Class: 'switch'
[17:35:54.969][E][component:255]:   unit4relay is marked FAILED: unspecified
<pre><code>esphome:
  friendly_name: relay-test
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
(... logger, api, wifi, ota, captive portal)
external_components:
  - source: github://m5stack/esphome-yaml/components@main
    components: unit4relay
    refresh: 0s
i2c:
  - id: i2c_bus
    sda: GPIO2
    scl: GPIO1
    scan: true
# M5Stack 4-Relay Module - each relay at its own address
unit4relay:
  i2c_id: i2c_bus
switch:
  - platform: unit4relay
    relay_1:
      name: "Base Relay Channel 1"
      restore_mode: RESTORE_DEFAULT_OFF
    relay_2:
      name: "Base Relay Channel 2"
    relay_3:
      name: "Base Relay Channel 3"
    relay_4:
      name: "Relay Channel 4"
<p dir="auto">And here for the atom (only different board and i2d ports)</p>
<pre><code>esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
    refresh: 0s
i2c:
  - id: i2c_bus
    sda: GPIO26
    scl: GPIO32
    scan: true
unit4relay:
  i2c_id: i2c_bus
switch:
    relay_1:
    relay_2:
    relay_3:
    relay_4:
]]></description><link>https://community.m5stack.com/topic/8126/issue-with-unit-4-relay-on-cores3</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:44:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8126.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Mar 2026 17:40:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issue with unit 4 relay on cores3 on Mon, 09 Mar 2026 19:57:31 GMT]]></title><description><![CDATA[<p dir="auto">On the cores3 (module connected through port A), I see no devices found on i2c scan when using esphome. It finds OK on the atom-lite.<br />
If using the "Cores3 test" binary from m5stack, I can see the address found on the i2c scan app.</p>
]]></description><link>https://community.m5stack.com/post/30749</link><guid isPermaLink="true">https://community.m5stack.com/post/30749</guid><dc:creator><![CDATA[ngolf]]></dc:creator><pubDate>Mon, 09 Mar 2026 19:57:31 GMT</pubDate></item></channel></rss>
