<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[bug?] Issue with axp2101 and module 4 relay (core base)]]></title><description><![CDATA[<p dir="auto">I'm having an issue where if I use the axp2101 component in esphome, my cores3-se-lite (connected to 12V via a DIN base) stops finding the module 4 relay (<a href="https://docs.m5stack.com/en/module/4relay" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/module/4relay</a>).</p>
<p dir="auto">This code works (I can hear the relays clicking, and see 0x26 on the i2c scan) (note custom component module4relay is basically unit4relay adapter for a different register to enable the relays)</p>
<pre><code>
esphome:
  friendly_name: relay-test-s3
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "Kh5g1ThAQ3SUqKw9GnyJUI5PyOkndNl4+ykbxHoUIjc="
ota:
  - platform: esphome
    password: "5f65f9ff9e4ab8b3c928a7216c551525"
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: "Relay-Test Fallback Hotspot"
    password: "G1ypogSTYlkb"
captive_portal:
i2c:
  - id: bus_internal
    sda: GPIO12
    scl: GPIO11
    scan: true
  - id: bus_port_a
    sda: GPIO2
    scl: GPIO1
    scan: true
external_components:
  - source: github://ngolf/esphome-yaml/components
    components: module4relay
module4relay:
  i2c_id: bus_internal
switch:
  - platform: module4relay
    relay_1:
      name: "Module Relay Channel 1"
      restore_mode: RESTORE_DEFAULT_OFF
    relay_2:
      name: "Module Relay Channel 2"
    relay_3:
      name: "Module Relay Channel 3"
    relay_4:
      name: "Module Channel 4"
<p dir="auto">But adding the axp2101 component (which I need for the backlight) makes the relay stopping being found on i2c scan, and relays inoperable.</p>
<pre><code>(external_components:)
axp2101:
]]></description><link>https://community.m5stack.com/topic/8128/bug-issue-with-axp2101-and-module-4-relay-core-base</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:47:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8128.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 Mar 2026 14:45:59 GMT</pubDate><ttl>60</ttl></channel></rss>
