<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ToF Hat only Short Range (UIflow2)]]></title><description><![CDATA[<p dir="auto">I have a problem with the ToF Hat (not the external I2C module).<br />
I tested the Hat with the Stick plus2 in the UIflow IDE and I can measure up to 2m without any problems. When I try to implement the same logic in the UIflow2 IDE, only Short Range seems to work, as the maximum measurement is 1.4m. This also happens with the Stick S3 in UIflow2.</p>
<p dir="auto">In UIflow, long range seems to be activated directly. However, I cannot find a block to set the ToF Hat to long range in UIflow2.<br />
There is official information that you have to set it to long range for 2 m, but I can't find how to do that.</p>
<p dir="auto">set_signal_rate_limit is available, but set_vcsel_pulse_period is not – that's what the M5 AI suggests.</p>
<p dir="auto">Who can help me with this?</p>
]]></description><link>https://community.m5stack.com/topic/8129/tof-hat-only-short-range-uiflow2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:12:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8129.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 Mar 2026 07:42:06 GMT</pubDate><ttl>60</ttl></channel></rss>
