<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unexpected results when using intensity slider for LED vontrol]]></title><description><![CDATA[<p dir="auto">Regarding  previous posts about the green LED control: I’ve implemented an intensity slider, but it’s behaving unexpectedly. The  light shifts to red instead of dimming the green. Interestingly, the color is correct when brightness is set manually to 100%. Does anyone have insight into what might be the reason?</p>
<p dir="auto"><img src="/assets/uploads/files/1773225106327-picture1.png" alt="Picture1.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/8132/unexpected-results-when-using-intensity-slider-for-led-vontrol</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:47:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8132.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Mar 2026 10:39:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unexpected results when using intensity slider for LED vontrol on Wed, 11 Mar 2026 14:08:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a> If I set them manually in the GreenSwitch and whiteSwitch it works fine</p>
]]></description><link>https://community.m5stack.com/post/30765</link><guid isPermaLink="true">https://community.m5stack.com/post/30765</guid><dc:creator><![CDATA[l.roca]]></dc:creator><pubDate>Wed, 11 Mar 2026 14:08:13 GMT</pubDate></item><item><title><![CDATA[Reply to Unexpected results when using intensity slider for LED vontrol on Wed, 11 Mar 2026 11:04:17 GMT]]></title><description><![CDATA[<p dir="auto">@l-roca what happens if you do intensity conversion outside  set brightness block then use this variable for set brightness to .... block</p>
<p dir="auto">other words does set brightness to 25, 50, 75 works fine with fixed values in it?</p>
]]></description><link>https://community.m5stack.com/post/30764</link><guid isPermaLink="true">https://community.m5stack.com/post/30764</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Wed, 11 Mar 2026 11:04:17 GMT</pubDate></item></channel></rss>
