<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Where to find source code for the builtin firmware?]]></title><description><![CDATA[<p dir="auto">I got the ESP32Cam. The AP+webserver that streams videos works fine. Good news.</p>
<p dir="auto">On the other hand, the CameraWebServer does not. It all seems fine, I can see the webpage with all the video controls, but when I press on 'start streaming', nothing happens.</p>
<p dir="auto">I am fine working out how to fix this, but I'd need the source code for the firmware so I can double check the settings (mostly GPIO pins I guess) that make the built-in version work fine.</p>
]]></description><link>https://community.m5stack.com/topic/816/where-to-find-source-code-for-the-builtin-firmware</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 12:37:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/816.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 Mar 2019 01:35:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Where to find source code for the builtin firmware? on Wed, 07 Aug 2019 08:07:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pacoblasco" aria-label="Profile: pacoblasco">@<bdi>pacoblasco</bdi></a> <a href="https://github.com/m5stack/m5stack-cam-psram" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/m5stack-cam-psram</a></p>
]]></description><link>https://community.m5stack.com/post/5056</link><guid isPermaLink="true">https://community.m5stack.com/post/5056</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 07 Aug 2019 08:07:08 GMT</pubDate></item><item><title><![CDATA[Reply to Where to find source code for the builtin firmware? on Sun, 04 Aug 2019 19:14:58 GMT]]></title><description><![CDATA[<p dir="auto">Where is the current firmware for ESP32CAM?<br />
<a href="https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram</a> is not available any more</p>
]]></description><link>https://community.m5stack.com/post/5012</link><guid isPermaLink="true">https://community.m5stack.com/post/5012</guid><dc:creator><![CDATA[PacoBlasco]]></dc:creator><pubDate>Sun, 04 Aug 2019 19:14:58 GMT</pubDate></item><item><title><![CDATA[Reply to Where to find source code for the builtin firmware? on Sun, 31 Mar 2019 01:49:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heybin" aria-label="Profile: heybin">@<bdi>heybin</bdi></a> / <a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a></p>
<p dir="auto">wow you guys are so fast!</p>
]]></description><link>https://community.m5stack.com/post/3455</link><guid isPermaLink="true">https://community.m5stack.com/post/3455</guid><dc:creator><![CDATA[joelhoro]]></dc:creator><pubDate>Sun, 31 Mar 2019 01:49:47 GMT</pubDate></item><item><title><![CDATA[Reply to Where to find source code for the builtin firmware? on Sun, 31 Mar 2019 01:47:04 GMT]]></title><description><![CDATA[<p dir="auto">Found a way to figure it out. The diagram on <a href="https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram</a> shows the GPIOs for the ESPCAM and apparently the D2 (pixel data Bit 0) is IO17 instead of IO32. Now the camerawebserver works (except for the LED not turning on but not a big deal).</p>
]]></description><link>https://community.m5stack.com/post/3454</link><guid isPermaLink="true">https://community.m5stack.com/post/3454</guid><dc:creator><![CDATA[joelhoro]]></dc:creator><pubDate>Sun, 31 Mar 2019 01:47:04 GMT</pubDate></item><item><title><![CDATA[Reply to Where to find source code for the builtin firmware? on Sun, 31 Mar 2019 01:43:08 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhoro" aria-label="Profile: joelhoro">@<bdi>joelhoro</bdi></a></p>
<p dir="auto">Here's the source code of "M5CamColorRecognition" for M5Camera (A Model). You can change the pin map for your ESP32CAM.</p>
<p dir="auto"><a href="https://github.com/m5stack/Applications-cam" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/Applications-cam</a></p>
<hr />
<p dir="auto">Factory firmware:<br />
<a href="https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram</a></p>
<p dir="auto">The docs:<br />
<a href="https://docs.m5stack.com/#/en/unit/esp32cam" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/unit/esp32cam</a></p>
]]></description><link>https://community.m5stack.com/post/3453</link><guid isPermaLink="true">https://community.m5stack.com/post/3453</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Sun, 31 Mar 2019 01:43:08 GMT</pubDate></item><item><title><![CDATA[Reply to Where to find source code for the builtin firmware? on Sun, 31 Mar 2019 01:39:03 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram</a><br />
Here you can see the code and GPIO pins</p>
]]></description><link>https://community.m5stack.com/post/3452</link><guid isPermaLink="true">https://community.m5stack.com/post/3452</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Sun, 31 Mar 2019 01:39:03 GMT</pubDate></item></channel></rss>
