<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Project] Flashlight ADV (V1.0) for M5Stack Cardputer - Smart Tactical Flashlight]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1774942959737-flashlight.png" alt="Flashlight.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Hi everyone!</p>
<p dir="auto">I just published a new utility for the <strong>Cardputer ADV</strong>. It's a highly optimized, state-machine-based flashlight that repurposes the TFT display as a multi-mode light source.</p>
<h3>⚡ Key Features</h3>
<li><strong>Smart Controls (Press ANY Key):</strong>
<li><strong>Single Click:</strong> Power ON/OFF. Features a Smart Memory system that remembers your last used color (White or Red).</li>
<li><strong>Double Click:</strong> High-speed Strobe mode (50ms interval).</li>
<li><strong>Hold (0.5s):</strong> Tactical Red Light mode to preserve night vision.</li>
</li>
<li><strong>Deep Battery Optimization:</strong> The ESP32-S3 CPU is automatically underclocked down to <strong>80MHz</strong>. This guarantees stable I2C/SPI operation while drastically reducing battery consumption and preventing any heat generation during long-term use.</li>
<li><strong>Hardware-Level Display Control:</strong> When turned off, the firmware kills the TFT backlight brightness to <code>0</code> and fills the VRAM with <code>TFT_BLACK</code> to completely halt power draw from the screen matrix.</li>
<h3>🧲 Practical Use Cases</h3>
<li><strong>Hands-Free Work:</strong> Thanks to the built-in magnets inside the Cardputer case, you can attach the device to server racks, car hoods, or any metal surface to illuminate your workspace.</li>
<li><strong>Night Vision Preservation:</strong> The dedicated Red Light mode is perfect for astronomy, reading in the dark, or tactical environments where standard white light is too harsh.</li>
<li><strong>Emergency Beacon:</strong> The high-frequency Strobe mode can be used as a distress signal or a highly visible marker on the road.</li>
<h3>🛠 How to install</h3>
<li><strong>M5Burner:</strong> The firmware is proprietary. You can install the binary directly by opening <strong>M5Burner</strong> and searching for <code>Flashlight ADV</code> or <code>Zeloksa</code>.</li>
<li><strong>Project Page / Issue Tracker:</strong> <a href="https://github.com/Zeloksa/Cardputer-Flashlight-ADV" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Zeloksa/Cardputer-Flashlight-ADV</a></li>
<h3>☕ Support the Project</h3>
<p dir="auto">If you find this utility useful for your EDC (Everyday Carry), consider supporting further development here: <a href="https://boosty.to/zeloksa" target="_blank" rel="noopener noreferrer nofollow ugc">https://boosty.to/zeloksa</a></p>
]]></description><link>https://community.m5stack.com/topic/8164/project-flashlight-adv-v1-0-for-m5stack-cardputer-smart-tactical-flashlight</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:36:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8164.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Mar 2026 07:47:09 GMT</pubDate><ttl>60</ttl></channel></rss>
