<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved]M5StickC firmware]]></title><description><![CDATA[<p dir="auto">I just got my M5StickC on Friday. It’s much smaller than I was expecting. It’s really tiny 😀. However, I powered it on and I don’t see anything on the screen. Holding it up to my ear, I hear faint clicking sounds so it seems like it’s doing something. I figured it would at least come with the UIFlow firmware installed, but I maybe not.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> please update the M5Burner for Mac to include the latest firmware for the M5StickC so I can try to flash it.  Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/820/solved-m5stickc-firmware</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:13:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/820.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Apr 2019 01:22:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Sat, 04 May 2019 06:06:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arzaman" aria-label="Profile: arzaman">@<bdi>arzaman</bdi></a> Just upload an arduino program in the normal way. It will overwrite the UIFlow bootloader and you can continue to use the devices.</p>
]]></description><link>https://community.m5stack.com/post/4113</link><guid isPermaLink="true">https://community.m5stack.com/post/4113</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 04 May 2019 06:06:20 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Fri, 03 May 2019 21:25:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a></p>
<p dir="auto">In my case is exactly the contrary...I got the M5Stick C with arduino bootloader FW and I burn UIflow with M5burner</p>
<p dir="auto">Now would like to revert to arduino...but no idea how to do and where to get the bootloader</p>
<p dir="auto">any idea ?</p>
<p dir="auto">Davide</p>
]]></description><link>https://community.m5stack.com/post/4107</link><guid isPermaLink="true">https://community.m5stack.com/post/4107</guid><dc:creator><![CDATA[arzaman]]></dc:creator><pubDate>Fri, 03 May 2019 21:25:50 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Fri, 03 May 2019 12:33:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arzaman" aria-label="Profile: arzaman">@<bdi>arzaman</bdi></a> said in <a href="/post/4103">M5StickC firmware</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a> thank ,</p>
<p dir="auto">so the same bootloader works for arduino IDE and UIflow ? if so is awesome</p>
<p dir="auto">so what is the "original" FW that is pre-loaded?<br />
If I udenrstand well the UIflow V1.2.3 loads on ESP32 micro python so sounds strange to me that once you have loaded the UIFlow FW you can use also with arduino IDE (C++)</p>
<p dir="auto">anyway I will try</p>
<p dir="auto">D.</p>
<p dir="auto">No it’s one FW or the other. The original FW should be uiFlow (MicroPython), at least for the recent hardware. The older hardware cores (M5Stack black or grey) shipped with a factory test Arduino sketch. All the newer hardware should ship with the uiFlow firmware.</p>
<p dir="auto">Flashing the hardware with the Arduino IDE will overwrite the uiFlow firmware. To get it back to uiFlow (MicroPython), use m5burner.</p>
]]></description><link>https://community.m5stack.com/post/4105</link><guid isPermaLink="true">https://community.m5stack.com/post/4105</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Fri, 03 May 2019 12:33:47 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Fri, 03 May 2019 08:10:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arzaman" aria-label="Profile: arzaman">@<bdi>arzaman</bdi></a> the esp32 has two cores, the firmware runs on one and user programmes run on the other core however, I was sure that Arduino programs wrote over the firmware giving access to both cores.</p>
]]></description><link>https://community.m5stack.com/post/4104</link><guid isPermaLink="true">https://community.m5stack.com/post/4104</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 03 May 2019 08:10:53 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Fri, 03 May 2019 07:29:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a> thank ,</p>
]]></description><link>https://community.m5stack.com/post/4103</link><guid isPermaLink="true">https://community.m5stack.com/post/4103</guid><dc:creator><![CDATA[arzaman]]></dc:creator><pubDate>Fri, 03 May 2019 07:29:06 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Fri, 03 May 2019 00:10:13 GMT]]></title><description><![CDATA[<p dir="auto">No need to “roll back.” The M5burner is only for UIFlow IDE. To use it with Arduino, just connect the USB from the m5stickC to your computer and upload any Arduino .ino sketch from the m5stickC examples. Follow the instructions from <a class="plugin-mentions-user plugin-mentions-a" href="/user/salty_good" aria-label="Profile: salty_good">@<bdi>salty_good</bdi></a> above to load the correct libraries into Arduino before uploading.</p>
]]></description><link>https://community.m5stack.com/post/4101</link><guid isPermaLink="true">https://community.m5stack.com/post/4101</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Fri, 03 May 2019 00:10:13 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Thu, 02 May 2019 23:11:54 GMT]]></title><description><![CDATA[<p dir="auto">I have upgraded via M5burner the FW of my M5Stack C to UIflow V1.2.3</p>
<p dir="auto">Is there any way to roll back and load the origina FW for using with the Arduino IDE ??<br />
From M5burner not clear what is the FW for Arduino IDE</p>
<p dir="auto">thanks<br />
Davide</p>
]]></description><link>https://community.m5stack.com/post/4099</link><guid isPermaLink="true">https://community.m5stack.com/post/4099</guid><dc:creator><![CDATA[arzaman]]></dc:creator><pubDate>Thu, 02 May 2019 23:11:54 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Fri, 05 Apr 2019 00:31:10 GMT]]></title><description><![CDATA[<p dir="auto">It’s all good. Keep up the great work. I love the m5 products!</p>
]]></description><link>https://community.m5stack.com/post/3546</link><guid isPermaLink="true">https://community.m5stack.com/post/3546</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Fri, 05 Apr 2019 00:31:10 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Thu, 04 Apr 2019 03:29:00 GMT]]></title><description><![CDATA[<p dir="auto">That's fine then as long as the hardware works. we will mark the mistake. Sorry for the inconvenient.</p>
]]></description><link>https://community.m5stack.com/post/3531</link><guid isPermaLink="true">https://community.m5stack.com/post/3531</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 04 Apr 2019 03:29:00 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Wed, 03 Apr 2019 11:13:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> said in <a href="/post/3516">M5StickC firmware</a>:</p>
<p dir="auto">The stickC should have the factory test code burned for default.  Please make sure the hardware doesn't have any problem. If the factory test firmware couldn't ran at all as you said didn't see anything on the screen, thats not normal, please test again and let me know if the factory test code works.</p>
<p dir="auto">The one I received did not have the factory test code on it upon arrival. Maybe mine slipped past quality control somehow.  However, I was able to burn the FactoryTest.ino sketch using the Arduino IDE and it works.</p>
]]></description><link>https://community.m5stack.com/post/3517</link><guid isPermaLink="true">https://community.m5stack.com/post/3517</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Wed, 03 Apr 2019 11:13:28 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Wed, 03 Apr 2019 06:36:46 GMT]]></title><description><![CDATA[<p dir="auto">The stickC should have the factory test code burned for default.  Please make sure the hardware doesn't have any problem. If the factory test firmware couldn't ran at all as you said didn't see anything on the screen, thats not normal, please test again and let me know if the factory test code works.</p>
]]></description><link>https://community.m5stack.com/post/3516</link><guid isPermaLink="true">https://community.m5stack.com/post/3516</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 03 Apr 2019 06:36:46 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Wed, 03 Apr 2019 02:16:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/salty_good" aria-label="Profile: salty_good">@<bdi>salty_good</bdi></a> thanks! the examples are working for me.</p>
]]></description><link>https://community.m5stack.com/post/3503</link><guid isPermaLink="true">https://community.m5stack.com/post/3503</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Wed, 03 Apr 2019 02:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Wed, 03 Apr 2019 01:59:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a> You can use M5StickC on Arduino IDE, Please search M5StickC library.</p>
<p dir="auto">Arduino IDE menu</p>
<p dir="auto">[Sketch] → [Include Library] → [Manage Libraries...] → search "m5stickc" → install<br />
Arduino IDE menu again after installed M5StickC library</p>
<p dir="auto">[File] → [Examples] → [M5StickC] → choose a sample as you like<br />
Have enjoy M5StickC!!</p>
]]></description><link>https://community.m5stack.com/post/3498</link><guid isPermaLink="true">https://community.m5stack.com/post/3498</guid><dc:creator><![CDATA[salty_good]]></dc:creator><pubDate>Wed, 03 Apr 2019 01:59:50 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Wed, 03 Apr 2019 00:28:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/salty_good" aria-label="Profile: salty_good">@<bdi>salty_good</bdi></a></p>
<p dir="auto">What should I use in the meantime? Arduino IDE? Does any firmware come preinstalled with the $1 for M5StickC version?</p>
]]></description><link>https://community.m5stack.com/post/3492</link><guid isPermaLink="true">https://community.m5stack.com/post/3492</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Wed, 03 Apr 2019 00:28:57 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5StickC firmware on Tue, 02 Apr 2019 09:38:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a> Hi, Thank you for your suggestion.<br />
We will soon prepare the M5Burner with M5StickC firmware for Mac.</p>
]]></description><link>https://community.m5stack.com/post/3490</link><guid isPermaLink="true">https://community.m5stack.com/post/3490</guid><dc:creator><![CDATA[salty_good]]></dc:creator><pubDate>Tue, 02 Apr 2019 09:38:51 GMT</pubDate></item></channel></rss>
