<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5burner software crash problem]]></title><description><![CDATA[<p dir="auto">After downloading and extracting the M5Burner software, my computer is unable to run the M5Burner.exe program. When I double-click M5Burner.exe, Windows directly displays a system pop-up message saying "m5burner has stopped working."</p>
<p dir="auto">The following solutions have been attempted but confirmed to be ineffective:<br />
· Extract the ZIP archive first, then run M5Burner.exe<br />
· Run M5Burner.exe as administrator<br />
· Ensure that M5Burner.exe and all other files from the archive are in the same directory, with the path using only half-width characters and the path length not exceeding the Windows system limit<br />
· Disable the system VPN and allow M5Burner.exe through the antivirus firewall<br />
· Restart the computer</p>
<p dir="auto">The following information is related to the error:<br />
· Operating environment: Windows 11 Pro 25H2 26200.8524<br />
· Information obtained from the m5burner.exe application crash event in Windows Event Viewer is as follows:<br />
Exception code: 0x80000003<br />
Faulting process ID: 0x893C</p>
]]></description><link>https://community.m5stack.com/topic/8243/m5burner-software-crash-problem</link><generator>RSS for Node</generator><lastBuildDate>Fri, 05 Jun 2026 07:01:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8243.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Jun 2026 17:27:01 GMT</pubDate><ttl>60</ttl></channel></rss>
