<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved]Ui Flow - encoder support]]></title><description><![CDATA[<p dir="auto">Hi there !<br />
there is any plans to add support for <a href="https://docs.m5stack.com/#/en/module/encoder" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/module/encoder</a> inside the Ui Flow ?</p>
]]></description><link>https://community.m5stack.com/topic/921/solved-ui-flow-encoder-support</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:10:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/921.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Apr 2019 19:16:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved]Ui Flow - encoder support on Mon, 22 Apr 2019 09:51:17 GMT]]></title><description><![CDATA[<p dir="auto">Yes, you can custom serials of blocks for FACES Kit.</p>
]]></description><link>https://community.m5stack.com/post/3908</link><guid isPermaLink="true">https://community.m5stack.com/post/3908</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 22 Apr 2019 09:51:17 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Ui Flow - encoder support on Fri, 19 Apr 2019 20:45:21 GMT]]></title><description><![CDATA[<p dir="auto">So, in flow:</p>
<p dir="auto">import i2c_bus<br />
i2c_l = i2c_bus.get(i2c_bus.PORTA)<br />
b = str(i2c_l.readfrom(0X5E,3))<br />
moving = b[4:6]<br />
clicking = b[8:10]</p>
<p dir="auto">I'm sure there's a better way to do this (with proper encoding). Clicking returns "1" if there is no clicking and "0" if there is. moving forward is 1,2,3,4,5 depending on speed and ff,fe,fd, etc... if it's going backwards.<br />
Should be simple to do a blocky version of this!</p>
]]></description><link>https://community.m5stack.com/post/3878</link><guid isPermaLink="true">https://community.m5stack.com/post/3878</guid><dc:creator><![CDATA[LastCaress]]></dc:creator><pubDate>Fri, 19 Apr 2019 20:45:21 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Ui Flow - encoder support on Fri, 19 Apr 2019 20:29:18 GMT]]></title><description><![CDATA[<p dir="auto">I figured out how to read the values from the encoder. My encoder is kinda crappy though, always a bad connection</p>
]]></description><link>https://community.m5stack.com/post/3877</link><guid isPermaLink="true">https://community.m5stack.com/post/3877</guid><dc:creator><![CDATA[LastCaress]]></dc:creator><pubDate>Fri, 19 Apr 2019 20:29:18 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Ui Flow - encoder support on Fri, 19 Apr 2019 19:44:23 GMT]]></title><description><![CDATA[<p dir="auto">If you do it, or start it, post it in the Projects forum.<br />
UIFlow is built on Micropython so I sure that you are correct.</p>
]]></description><link>https://community.m5stack.com/post/3876</link><guid isPermaLink="true">https://community.m5stack.com/post/3876</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 19 Apr 2019 19:44:23 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Ui Flow - encoder support on Fri, 19 Apr 2019 19:28:01 GMT]]></title><description><![CDATA[<p dir="auto">I think it'd be possible to write custom blocks for it</p>
]]></description><link>https://community.m5stack.com/post/3875</link><guid isPermaLink="true">https://community.m5stack.com/post/3875</guid><dc:creator><![CDATA[LastCaress]]></dc:creator><pubDate>Fri, 19 Apr 2019 19:28:01 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Ui Flow - encoder support on Fri, 19 Apr 2019 19:23:59 GMT]]></title><description><![CDATA[<p dir="auto">From what I understand, the faces units are aimed more towards industrial and so are unsupported in UIFlow.</p>
]]></description><link>https://community.m5stack.com/post/3874</link><guid isPermaLink="true">https://community.m5stack.com/post/3874</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 19 Apr 2019 19:23:59 GMT</pubDate></item></channel></rss>
