<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack problem with Connecting to WIFI]]></title><description><![CDATA[<p dir="auto">Most of the time WiFi.begin() is failing on my M5Stack fire. I use the Arduino IDE. The same thing with an ESP32 always works. I have seen several references to this problem but not a clear resolution. I prefer to stay using the Arduino IDE. Any help gratefully received. My first post, hope I have done it right!.</p>
]]></description><link>https://community.m5stack.com/topic/924/m5stack-problem-with-connecting-to-wifi</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 19:51:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/924.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Apr 2019 20:46:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack problem with Connecting to WIFI on Tue, 23 Apr 2019 06:40:55 GMT]]></title><description><![CDATA[<p dir="auto">Thinking more about it. Its probably that when the Fire is fully assembled it requires a stronger WiFi signal, perhaps due to the proximity of the other components.</p>
]]></description><link>https://community.m5stack.com/post/3935</link><guid isPermaLink="true">https://community.m5stack.com/post/3935</guid><dc:creator><![CDATA[LordInchcape]]></dc:creator><pubDate>Tue, 23 Apr 2019 06:40:55 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack problem with Connecting to WIFI on Tue, 23 Apr 2019 06:26:26 GMT]]></title><description><![CDATA[<p dir="auto">Yes. Last night I made some progress. Its power related. It will work if I get close to the modem. I have a Fire and it also works just like ESP32 if I detach the core from the stack. So I think its a slight difference when running from the battery. In all circumstances it will successfully scan for WiFi networks, so connection  must use a bit for power.</p>
]]></description><link>https://community.m5stack.com/post/3934</link><guid isPermaLink="true">https://community.m5stack.com/post/3934</guid><dc:creator><![CDATA[LordInchcape]]></dc:creator><pubDate>Tue, 23 Apr 2019 06:26:26 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack problem with Connecting to WIFI on Mon, 22 Apr 2019 09:35:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lordinchcape" aria-label="Profile: LordInchcape">@<bdi>LordInchcape</bdi></a><br />
Do you mean it's hard to connect to wifi with M5Stack fire using WIFI.begin(), but easy with other ESP32 board ?</p>
]]></description><link>https://community.m5stack.com/post/3906</link><guid isPermaLink="true">https://community.m5stack.com/post/3906</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 22 Apr 2019 09:35:39 GMT</pubDate></item></channel></rss>
