<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5stack core solar panel]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I want to add a solar panel directly on the module M5stack core. I have try to connect with usb C a solar panel but it don't work.. i have try to charge my phone and this work.<br />
The battery inside was a lithium 3,7V 150mA. I find a solar panel with 5v can be use to charge the battery.  Because i can use the module just 40min...</p>
<p dir="auto">Someone have an idea to connect the module with solar panel please?</p>
]]></description><link>https://community.m5stack.com/topic/982/m5stack-core-solar-panel</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:22:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/982.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 May 2019 13:15:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5stack core solar panel on Mon, 06 May 2019 15:13:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kat" aria-label="Profile: kat">@<bdi>kat</bdi></a> you need something <a href="https://www.aliexpress.com/item/5Color-Dual-USB-LED-PCBA-Circuit-Board-Solar-Power-Panel-For-18650-Battery-DIY-Home-Portable/32817319450.html?spm=2114.search0104.3.1.3f1b5521M1vTtt&amp;ws_ab_test=searchweb0_0,searchweb201602_7_10065_10130_10068_10547_319_317_10548_10696_10192_10190_453_10084_454_10083_10618_10307_10820_10301_10821_10303_537_536_10059_10884_10887_321_322_10103,searchweb201603_52,ppcSwitch_0&amp;algo_expid=71fa3e47-1518-4019-b9f1-b463921570a2-0&amp;algo_pvid=71fa3e47-1518-4019-b9f1-b463921570a2&amp;transAbTest=ae803_4" target="_blank" rel="noopener noreferrer nofollow ugc">like this</a> that has a solar charge controller that charges batteries and then uses the batteries to power the M5Stack through the USB.</p>
]]></description><link>https://community.m5stack.com/post/4162</link><guid isPermaLink="true">https://community.m5stack.com/post/4162</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 06 May 2019 15:13:52 GMT</pubDate></item><item><title><![CDATA[Reply to M5stack core solar panel on Mon, 06 May 2019 14:48:43 GMT]]></title><description><![CDATA[<p dir="auto">okay but how do i connect after on the module?</p>
]]></description><link>https://community.m5stack.com/post/4159</link><guid isPermaLink="true">https://community.m5stack.com/post/4159</guid><dc:creator><![CDATA[kat]]></dc:creator><pubDate>Mon, 06 May 2019 14:48:43 GMT</pubDate></item><item><title><![CDATA[Reply to M5stack core solar panel on Mon, 06 May 2019 13:58:18 GMT]]></title><description><![CDATA[<p dir="auto">Doesn't work like that, you need a solar setup capable of 500mA @5V minimum.</p>
<p dir="auto">(just been out and measured.)</p>
]]></description><link>https://community.m5stack.com/post/4155</link><guid isPermaLink="true">https://community.m5stack.com/post/4155</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 06 May 2019 13:58:18 GMT</pubDate></item></channel></rss>
