    Core INK freezes after a couple of minutes
    13 Posts 4 Posters 12.0k Views
    • N Offline
      Navidard
      Hi everyone,
      I am very new to this, so sorry if my question might be a bit too obvious.
      I have made a CO2 monitor on UIFLOW using CORE Ink and a CO2 module. it shows the data on the screen and also I used REMOTE+ to read the data on my phone.
      Everything works well for around 5 minutes and then Core INK freezes. I have no idea why.
      Can you please help me diagnose this?0_1672412560299_Screenshot 2022-12-30 155652.png
        Hello @Navidard
        try without ezdata - it looks like it looks up after a couple of updates.
          Hello @Navidard
          try without ezdata - it looks like it locks up after a couple of updates.
            It may be memory error, I did have issues running sensors on the controllers filling memory and not clearing the memory.
              Red253
              attempt without ezdata - it seems as though it secures after two or three updates.
              Much obliged
                Add an execute block to the begging of the program loop and in the block add the following
                import gc
                gc.collect()
                This should force micropython to preform garbage collection freeing up memory.
                • N Offline
                  Navidard @ajb2k3
                  @ajb2k3 Thanks a lot! it seems like it's working for now!
                  • N Offline
                    Navidard @felmue
                    @felmue Thanks for the advice.
                    I added a restart after every 120 seconds to save battery, and downloaded the code to the device, but then every time it restarts, it shows the UIflow logo, beeps, etc etc, until it gets to my application page. Do you have any idea why this happens?
                      Hello @Navidard
                      I assume by restart you mean shutdown and restart. So yes, that is how UIFlow works. When the device restarts UIFlow firmware is started and eventually your code gets executed.
                        ajb2k3 @Navidard
                        @navidard I went through so much IOT headache before I discovered this. So glad it works.
                        • N Offline
                          Navidard @ajb2k3
                          @ajb2k3 Hello, so after fiddling with it yesterday, I understood the same thing still happens. it works for longer periods, but then stops responding again and dies. This is the sketch I am using now:0_1673345363895_Screenshot 2023-01-10 110905.png
                            ajb2k3 @Navidard
                            @navidard said in Core INK freezes after a couple of minutes:
                            The GC block needs to be inside the If>do loop.
                            I'm not sure if its a bug as gc.collect() is supposed to run continuously but Inside a loop it forces a reset of gc.collect()
                            Try putting an execute code block containing import gc next to start and then gc.collect() at the beginning of the if loop
                            I don't see a main loop function and so to me the code looks to be running in "One Shot" mode and not repeating.
                            • N Offline
                              Navidard @ajb2k3
                              @ajb2k3 Yes I removed the loop because I wanted to add the restart option at the end of the code to use the low power mode basically.
                              So now, it restarts, reads and sends the data, and goes to sleep.
