    M5sTACK ATOM LITE with PbHUB and sensors: how do I set this up for ESPHOME?
    5 Posts 3 Posters 8.8k Views
    • G Offline
      gunnm
      I have a M5sTACK ATOM LITE (https://docs.m5stack.com/#/en/core/atom_lite). Via the PbHUB (https://docs.m5stack.com/en/unit/pbhub AND https://github.com/m5stack/M5Stack/tree/master/examples/Unit/PbHUB) I connect the following sensors in this order into the ports of the PbHUB:
      On CH0: TVOC/eCO2 (https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/unit/Sensirion_Gas_Sensors_SGP30_Datasheet.pdf)
      On CH1: ENV III (https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/unit/enviii/QMP6988 Datasheet.pdf + https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/unit/SHT3x_Datasheet_digital.pdf)
      On CH2: DLight Unit (https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/hat/BH1750FVI).
      On CH3: Microphone Unit (LM393) (https://docs.m5stack.com/en/unit/mic).
      In the Home Assistant I have ESPHOME and the following YAML:
      esphome:
      friendly_name: ESPHome Web 06c2e0 ATOM
      esp32:
      board: esp32dev
      framework:
      type: arduino
      logger:
      api:
      encryption:
      key: !secret
      ota:
      wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      ap:
      ssid: !secret
      password: !secret
      captive_portal:
      spi:
      clk_pin: 18
      mosi_pin: 23
      miso_pin: 26
      i2c:
      • sda: 26
        scl: 32
        scan: true
        frequency: 400 kHz
      sensor:
      • platform: sgp30
        address: 0x58
        eco2:
        accuracy_decimals: 1
        tvoc:
        update_interval: 1s
        baseline:
        eco2_baseline: 0x86C5
        tvoc_baseline: 0x8B38
      • platform: sht3xd
        temperature:
        humidity:
        address: 0x44
        update_interval: 1s
      • platform: qmp6988
        temperature:
        oversampling: 16x
        pressure:
        oversampling: 64x
        address: 0x61
        update_interval: 1s
        iir_filter: 2x
      • platform: bh1750
        address: 0x61
        update_interval: 1s
        address: 0x61
        update_interval: 1s
      The sensors are displayed. But the values are wrong. Here still the LOG:
      [10:53:37][C][logger:293]: Logger:
      [10:53:37][C][logger:294]: Level: DEBUG
      [10:53:37][C][logger:295]: Log Baud Rate: 115200
      [10:53:37][C][logger:296]: Hardware UART: UART0
      [10:53:37][C][spi:101]: SPI bus:
      [10:53:37][C][spi:102]: CLK Pin: GPIO18
      [10:53:37][C][spi:103]: MISO Pin: GPIO26
      [10:53:37][C][spi:104]: MOSI Pin: GPIO23
      [10:53:37][C][spi:106]: Using HW SPI: YES
      [10:53:37][C][i2c.arduino:052]: I2C Bus:
      [10:53:37][C][i2c.arduino:053]: SDA Pin: GPIO26
      [10:53:37][C][i2c.arduino:054]: SCL Pin: GPIO32
      [10:53:37][C][i2c.arduino:055]: Frequency: 400000 Hz
      [10:53:37][C][i2c.arduino:058]: Recovery: bus successfully recovered
      [10:53:37][I][i2c.arduino:068]: Results from i2c bus scan:
      [10:53:37][I][i2c.arduino:074]: Found i2c device at address 0x61
      [10:53:37][C][sgp30:220]: SGP30:
      [10:53:37][C][sgp30:221]: Address: 0x58
      [10:53:37][W][sgp30:237]: Unknown setup error!
      [10:53:37][C][sgp30:251]: Update Interval: 1.0s
      [10:53:37][C][sgp30:252]: eCO2 sensor 'eCO2'
      [10:53:37][C][sgp30:252]: Device Class: 'carbon_dioxide'
      [10:53:37][C][sgp30:252]: State Class: 'measurement'
      [10:53:37][C][sgp30:252]: Unit of Measurement: 'ppm'
      [10:53:37][C][sgp30:252]: Accuracy Decimals: 1
      [10:53:37][C][sgp30:252]: Icon: 'mdi:molecule-co2'
      [10:53:37][C][sgp30:253]: TVOC sensor 'TVOC'
      [10:53:37][C][sgp30:253]: Device Class: 'volatile_organic_compounds'
      [10:53:37][C][sgp30:253]: State Class: 'measurement'
      [10:53:37][C][sgp30:253]: Unit of Measurement: 'ppb'
      [10:53:37][C][sgp30:253]: Accuracy Decimals: 1
      [10:53:37][C][sgp30:253]: Icon: 'mdi:radiator'
      [10:53:37][C][sgp30:256]: Store baseline: YES
      [10:53:37][C][sgp30:262]: Compensation: No source configured
      [10:53:37][C][sht3xd:029]: SHT3xD:
      [10:53:37][C][sht3xd:030]: Address: 0x44
      [10:53:37][E][sht3xd:032]: Communication with SHT3xD failed!
      [10:53:37][C][sht3xd:034]: Update Interval: 1.0s
      [10:53:37][C][sht3xd:036]: Temperature 'Temperatur SHT30'
      [10:53:37][C][sht3xd:036]: Device Class: 'temperature'
      [10:53:37][C][sht3xd:036]: State Class: 'measurement'
      [10:53:37][C][sht3xd:036]: Unit of Measurement: '°C'
      [10:53:37][C][sht3xd:036]: Accuracy Decimals: 1
      [10:53:37][C][sht3xd:037]: Humidity 'Luftfeuchtigkeit'
      [10:53:37][C][sht3xd:037]: Device Class: 'humidity'
      [10:53:37][C][sht3xd:037]: State Class: 'measurement'
      [10:53:37][C][sht3xd:037]: Unit of Measurement: '%'
      [10:53:37][C][sht3xd:037]: Accuracy Decimals: 1
      [10:53:37][C][qmp6988:368]: QMP6988:
      [10:53:37][C][qmp6988:369]: Address: 0x61
      [10:53:37][C][qmp6988:373]: Update Interval: 1.0s
      [10:53:37][C][qmp6988:375]: Temperature 'Temperatur QMP6988'
      [10:53:37][C][qmp6988:375]: Device Class: 'temperature'
      [10:53:37][C][qmp6988:375]: State Class: 'measurement'
      [10:53:37][C][qmp6988:375]: Unit of Measurement: '°C'
      [10:53:37][C][qmp6988:375]: Accuracy Decimals: 1
      [10:53:37][C][qmp6988:376]: Temperature Oversampling: 16x
      [10:53:37][C][qmp6988:377]: Pressure 'Luftdruck'
      [10:53:37][C][qmp6988:377]: Device Class: 'pressure'
      [10:53:37][C][qmp6988:377]: State Class: 'measurement'
      [10:53:37][C][qmp6988:377]: Unit of Measurement: 'hPa'
      [10:53:37][C][qmp6988:377]: Accuracy Decimals: 1
      [10:53:37][C][qmp6988:378]: Pressure Oversampling: 64x
      [10:53:37][C][qmp6988:379]: IIR Filter: 2x
      [10:53:37][D][qmp6988:389]: Temperature=44.34°C, Pressure=-4106.19hPa
      [10:53:37][D][sensor:127]: 'Temperatur QMP6988': Sending state 44.33594 °C with 1 decimals of accuracy
      [10:53:38][D][sensor:127]: 'Luftdruck': Sending state -4106.18994 hPa with 1 decimals of accuracy
      [10:53:38][C][bh1750.sensor:118]: BH1750 'LUX'
      [10:53:38][C][bh1750.sensor:118]: Device Class: 'illuminance'
      [10:53:38][C][bh1750.sensor:118]: State Class: 'measurement'
      [10:53:38][C][bh1750.sensor:118]: Unit of Measurement: 'lx'
      [10:53:38][C][bh1750.sensor:118]: Accuracy Decimals: 1
      [10:53:38][C][bh1750.sensor:119]: Address: 0x61
      [10:53:38][C][bh1750.sensor:124]: Update Interval: 1.0s
      [10:53:38][C][captive_portal:088]: Captive Portal:
      [10:53:38][C][mdns:108]: mDNS:
      [10:53:38][C][mdns:109]: Hostname: esphome-web-06c2e0
      [10:53:38][C][ota:093]: Over-The-Air Updates:
      [10:53:38][C][ota:094]: Address: esphome-web-06c2e0.local:3232
      [10:53:38][C][api:138]: API Server:
      [10:53:38][C][api:139]: Address: esphome-web-06c2e0.local:6053
      [10:53:38][C][api:141]: Using noise encryption: YES
      [10:53:38][D][bh1750.sensor:159]: 'LUX': Got illuminance=28.9lx
      [10:53:38][D][sensor:127]: 'LUX': Sending state 28.86319 lx with 1 decimals of accuracy
      [10:53:38][D][qmp6988:389]: Temperature=44.34°C, Pressure=-4106.19hPa
      [10:53:38][D][sensor:127]: 'Temperatur QMP6988': Sending state 44.33594 °C with 1 decimals of accuracy
      Have already tried a few things, but just do not get to the goal! Thanks for your help!
        DIYGuy
        Im after help on this also.
        see here for a lead on using the hub
        https://github.com/Chill-Division/M5Stack-ESPHome/blob/main/IO Hub 1 to 6 Expansion Unit (STM32F0).md
        I would like to hire someone who can do integrations in esphome
        • teastainT Offline
          teastain @gunnm
          @gunnm Hi!
          PbHub is for digital I/O. (like switches)
          It is not for I2C devices. (like ENVIII)
          -Terry
          • G Offline
            gunnm @teastain
            @teastain Hello
            Thank you for the feedback. But how do I get all the sensors through the ATOM? PaHub? Or are there other possibilities?
            • teastainT Offline
              teastain @gunnm
              @gunnm I do not have any experience with ESPHOME, I use Arduino and write directly with C, C++! The PaHub (named after the 'Grove port A' I2C port in the M5Stack system) is an i2c expander. So if you have a bunch of i2c devices they can be plugged in and "polled" and read over a single i2c connection. The devices can even have the same i2c address, like having two ENV sensors, without conflict. Works very well. 'Polled' is where sensors are read one at a time and their value 'at that moment' is read and transmitted to the Atom
              The PbHub (also polled) on the other hand connects to your controller the same way, i2c, but hosts almost any 'discrete' sensor like a switch or a lamp (GPIO, PWM, Servo control, ADC sampling, RGB light control) but remember that it has to squish the signals of all those devices into one i2c channel, so some very high speed devices may jitter. Very short signals such as an encoder blip could be missed altogether, periodically.
              -Terry
