    Core 2 MQQT fails to publish on topic
    5 Posts 3 Posters 4.1k Views
      colmana
      I have followed various MQTT tutorials , none of them mention about connecting to the internet via WiFi before running the MQTT protocols, they just show the MQTT Code?
      Am I correct in assuming that M5FLOW requires you to connect to a WiFi connection ? or does the code auto connect using the last known WiFi SSID and Password ??
      Does anyone have a full example of code that works .
      I am using a cloud Broker and have succesfully set up and tested using Android clients so I know the credentials and so on are correct,.
      Any pointers or help greatly appreciated.
      • felmueF Online
        Hello @colmana
        in my experience it depends. If you use Run then the already setup WiFi connection (which is used to connect to UIFlow server) is used.
        However when you use Download it only works until you reboot your device.
        So what I do in my UIFlow programs which need WiFi: I add the necessary block in setup anyways.
        See this thread about how to do that.
          As @felmue has said, If you run it live using the run button, it will connect to which ever network the S3device is connected to where as if you use the download you need to have the Wifi credential blocks added to the setup.
          What MQTT guides have you been following?
          I have a standalone MQTT server on an M5Stack CM4 Stack running to test MQTT and IOT.
            colmana @felmue
            many thanks for your helpful reply , I managed to get it working by adding the wifi code blocks , you r link was of interest too !
            cheers
            Alan
              colmana @ajb2k3
              started with this https://youtu.be/5RozKI-3i4Q..
              My project is to monitor power , security , humidity , temperature and water leaks at a remote business premises . Thats part 1
              Part 2 is to push actions over MQQT based on reports .
              Will be using a Stick C plus for sensing and Core 2 at home plus Andoid app for real time alert.
