    Not able to pair Core2 with my account
    7 Posts 4 Posters 7.6k Views 3 Watching
      mchott
      After downloading the new firmware UI Flow2 for my Core2 and the first burn, I was requested to pair the device with my account and there was an error. The burning was at the end successful as "private" without an account. Now I can not add this device to my account and as it is set to private (what I can not change) I can not use the device with an public key.
      Reburning or re download the firmware, erease and so on .. I did all things without success.
      • sirspotS Offline
        sirspot
        I tried to get my core2 working with uiflow 2 but also could not make much progress. I went back to latest uiflow 1.0 with no problems.
          mchott @sirspot
          @sirspot Yes it´s possible to go back to the latest UiFlow 1
          I just wanted to test what is possible with UiFlow 2. This tiny project has it´s limitations with UiFlow 1 and before I switch to developing with Arduino or Micropython or whatever I just wanted to try UiFlow 2 because it´s now available.
            ajb2k3 @mchott
            @mchott you don’t need to switch to Micropython as UIFlow is built on Micropython. You can use an ide like Thonny to extend the UIFlow/Micropython program and using thonny, you can load the file off the core2 and keep developing.
            Switching to arduino does have some be if it’s but also has major headaches
              RASBR
              Hi @mchott
              I am stuck like you with private device without being able to connect to UiFlow2.
              Did you find a solution yet?
                mchott @RASBR
                @rasbr no .. I tried many things and have no solution
                "you don’t need to switch to Micropython as UIFlow is built on Micropython" .. yes I know but it´s different of using the blockly UI or just write lines of code. Yes both is possible with UIflow but if I decide for more functionallity and using Micropython in UIflow there is no real way back. In my opinion this is a way between. Blockly UIflow > Micropython UIflow > Arduino IDE > ...
                  mchott @mchott
                  @mchott the only thing right now .. after whatever .. it appears in the menu in UIflow 2 .. but I don´t have any idea what this caused
