    Connect COM.LTE to CoreS3?
    12 Posts 3 Posters 12.1k Views
      Hello @aezero
      You are correct, on M5CoreS3 GPIO1 and GPIO2 are used for external I2C.
      I suggest you set COM.LTE to use pins 16 / 17 and then use GPIO18 / 17 in your code. AFAIK PC_RX and PC_TX are the second serial.
        aezero @felmue
        Hi Felix! Good to hear from you again!
        Thanks for the clarification! The second serial connection is the blue connector, right?
          aezero
          Looking at the pinout diagrams with some refreshed eyes and I see it now... "PA" is short for "Port A" and "PC" is short for "Port C". And PA has a red background, like the red Port A connector, and PC is in the same light blue as Port C's connector.
          alt text
            Hello @aezero
            thank you for pointing that out as I haven't noticed that myself - even the background color matches the connectors.
              aezero
              And on further examination, there's the dark grey PB_IN and PB_OUT pins, at G8 and G9. The splash screen when you power it on shows G8 and G9 are on Port B (there's a typo, saying "Port.C" but it's in the position of the black Port B connector).
              alt text
                aezero
                I just made another discovery. If you power it up with the factory demo software, go the home screen, and then tap on "CORES3" six times, it puts you into a factory test mode
                  Cohen
                  I have the M5CoreS3 and the Com.x LTE, not having any success communicating with the COM.X LTE. the dips are on the default 5/13.
                  what should they be set too? and is there any simple Example Test of LTE for me to test and follow??
                  I see this comment
                  "I suggest you set COM.LTE to use pins 16 / 17 and then use GPIO18 / 17 in your code. AFAIK PC_RX and PC_TX are the second serial."
                  not sure if just Dip 5 should change to 16 or 17?? help appreciated.
                  also in the Code is there a command to tell how to communicate with those different PINS??
                  first time use of the LTE.
                  thanks
                    Hello @Cohen
                    please find a simple test for the communication between M5CoreS3 and COM.LTE module.
                    In the COM.LTE module set the DIP switches as follows:
                    15 - off
                     5 - off
                    16 - on
                    13 - off
                     0 - off
                    17 - on
                    Note: my COM.LTE module takes about 15 seconds (after power on) until it is ready and responds with AT OK.
                      Cohen @felmue
                      @felmue said in Connect COM.LTE to CoreS3?:
                      test
                      I give this a go. thanks
                        Cohen
                        Thanks that did it.
                        I got a res: AT OK.
                        thanks.
                        I am trying to use TinyGSM
                        has any one got it working with he Core3 COM.X LTE?
                        but with no luck. get the following:-
                        22:44:52.276 -> [6988] Trying baud rate 115200 ...
                        22:45:02.304 -> [16999] Trying baud rate 57600 ...
                        22:45:12.314 -> [27009] Trying baud rate 38400 ...
                        22:45:22.312 -> [37019] Trying baud rate 19200 ...
                        22:45:32.324 -> [47029] Trying baud rate 9600 ...
                        22:45:42.325 -> [57039] Trying baud rate 74400 ...
                        22:45:52.334 -> [67049] Trying baud rate 74880 ...
                        22:46:02.336 -> [77059] Trying baud rate 14400 ...
                        22:46:12.356 -> [87069] Trying baud rate 28800 ...
                        22:46:22.358 -> [97079] Initializing modem...
                        22:46:32.393 -> [107111] Failed to restart modem, delaying 10s and retrying
                        22:46:32.393 -> [107111] Initializing modem...
                        22:46:42.440 -> [117143] Failed to restart modem, delaying 10s and retrying
                        22:46:42.440 -> [117143] Initializing modem...
                        22:46:52.451 -> [127175] Failed to restart modem, delaying 10s and retrying
                        22:46:52.454 -> [127175] Initializing modem...
                          Cohen
                          Got a bit further in the quest.
                          I added the following:-
                          // Set console baud rate
                          SerialMon.begin(115200);
                          delay(10);
                          SerialAT.begin(115200, SERIAL_8N1, 18, 17, false);
                          delay(3000);
                          modem.restart();
                          and got some responses
                          23:06:21.706 -> [14189] Wait...
                          23:06:27.695 -> [20189] Trying baud rate 115200 ...
                          23:06:30.064 -> [22535] Modem responded at rate 115200
                          23:06:30.064 -> [22535] Initializing modem...
                          23:06:35.068 -> [27555] ### TinyGSM Version: 0.11.7
                          23:06:35.068 -> [27555] ### TinyGSM Compiled Module: TinyGsmClientSIM7600
                          23:06:45.272 -> [37756] Failed to restart modem, delaying 10s and retrying
                          23:06:45.272 -> [37756] Initializing modem...
                          23:06:55.486 -> [47957] Failed to restart modem, delaying 10s and retrying
                          23:06:55.486 -> [47957] Initializing modem...
                          23:07:03.779 -> [56269] ### TinyGSM Version: 0.11.7
                          23:07:03.779 -> [56269] ### TinyGSM Compiled Module: TinyGsmClientSIM7600
                          23:07:03.843 -> [56316] ### Modem: SIMCOM SIM7600G-H
                          23:07:03.877 -> [56369] ### Modem: SIMCOM SIM7600G-H
                          23:07:03.877 -> [56369] Modem Name: SIMCOM SIM7600G-H
                          23:07:03.910 -> [56397] Modem Info: Manufacturer: SIMCOM INCORPORATED Model: SIMCOM_SIM7600G-H Revision: SIM7600G_V2.0.2 IMEI: "redacted" +GCAP: +CGSM
                          23:07:03.910 -> [56397] Waiting for network...
                          23:07:03.975 -> [56440] Network connected
                          23:07:03.975 -> [56440] Connecting to vsh.pp.ua
                          23:07:04.008 -> [56482] ... failed
                          23:07:04.008 -> [56482] Requesting current network time
                          23:07:04.008 -> [56484] Couldn't get network time, retrying in 15s.
                          23:07:18.986 -> [71484] Requesting current network time
                          23:07:19.025 -> [71486] Year: 2024 Month: 1 Day: 26
                          23:07:19.025 -> [71486] Hour: 23 Minute: 7 Second: 3
                          23:07:19.025 -> [71486] Timezone: 11.00
                          23:07:19.025 -> [71487] Retrieving time again as a string
                          23:07:19.025 -> [71506] Current Network Time: 24/01/26,23:07:18+44
                          23:07:19.185 -> [71672] Battery charge state: 0
                          23:07:19.185 -> [71672] Battery charge 'percent': 0
                          23:07:19.185 -> [71672] Battery voltage: 3.80
                          23:07:19.219 -> [71691] Chip temperature: 37.00
                          23:07:19.219 -> [71691] End of tests.
