    Connecting multi TOF4m units via PA.hub - weird behaviour
    15 Posts 6 Posters 9.9k Views 1 Watching
      felmue @sqbaczek
      Hello @sqbaczek
      assuming the programming is correct my best guess would be that the two ToF4m influence each other due to the signal they both send out. Maybe the signal of one gets reflected from the walls and then is picked up by both (and vice versa)?
      BTW: have you tried the UIFlow2 instead? Do you get the same results?
        sqbaczek @felmue
        Greetings @felmue!
        Thank you for your reply,
        Even if I space apart both sensors and direct them in different spots - they still get weird readings. As soon as I disconnect one of them from pa.hub one label gets proper readings - and other gets very simillar reading to first label (even though it is linked with disconnected sensor).
        Below screenshot of readings with one sensor disconnected from pa.hub - and both labels change as soon as I get some object near the connected sensor.
        For UIflow 1 code is:
        from m5stack import *
        from m5ui import *
        from uiflow import *
        import time
        import unit
        setScreenColor(0x222222)
        tof4m_0 = unit.get(unit.TOF4M, unit.PAHUB0)
        tof4m_1 = unit.get(unit.TOF4M, unit.PAHUB2)
        label0 = M5TextBox(43, 36, "label0", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        label1 = M5TextBox(45, 88, "label1", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        while True:
          label0.setText(str((str('odl 1 ') + str(((str(((tof4m_0.get_single_distance_value) / 10)) + str('cm')))))))
          label1.setText(str((str('odl 2 ') + str(((str(((tof4m_1.get_single_distance_value) / 10)) + str('cm')))))))
          wait_ms(500)
          wait_ms(2)
        When I try to run it on UIflow 2.0 with pa.hub I get error:
        File "<stdin>", line 29, in <module>
        File "<stdin>", line 20, in setup
        File "driver/vl53l1x.py", line 60, in init
        File "driver/vl53l1x.py", line 176, in get_model_info
        File "driver/vl53l1x.py", line 273, in _read_register
        TypeError: unexpected keyword argument 'addrsize'
        This is my code for uiflow 2 - and it does not work
        import os, sys, io
        import M5
        from M5 import *
        from hardware import *
        from unit import TOF4MUnit
        from unit import PAHUBUnit
        label0 = None
        label1 = None
        i2c1 = None
        pahub_0 = None
        tof4m_2 = None
        tof4m_0 = None
        def setup():
          global label0, label1, i2c1, pahub_0, tof4m_2, tof4m_0
          M5.begin()
          Widgets.fillScreen(0x222222)
          label0 = Widgets.Label("label0", 44, 65, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
          label1 = Widgets.Label("label1", 43, 111, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
          i2c1 = I2C(1, scl=Pin(22), sda=Pin(21), freq=100000)
          tof4m_0 = TOF4MUnit(PAHUBUnit(i2c=i2c1, channel=1), 0x29)
          tof4m_2 = TOF4MUnit(PAHUBUnit(i2c=i2c1, channel=0), 0x29)
        def loop():
          M5.update()
          label0.setText(str((str('Odl1 ') + str((tof4m_2.get_distance)))))
          label0.setText(str((str('Odl2 ') + str((tof4m_0.get_distance)))))
        if __name__ == '__main__':
          try:
            setup()
            while True:
              loop()
            try:
              print_error_msg(e)
            except ImportError:
        Thank you for help,
        best,
        Matt
        felmueF E 2 Replies Last reply Reply Quote 0
          felmue @sqbaczek
          Hello @sqbaczek
          unfortunately I don't have the proper hardware, e.g. TOF4m unit, so I cannot test this myself. Sorry.
          BTW: are you aware that in UIFlow1 you use PaHUB channel 0 and 2 and in UIFlow2 you setup PaHUB channel 0 and 1.
            sqbaczek @felmue
            Hi @felmue,
            thanks for response - yes I have tried different ports on PA.hub so between two uiflows sensors might have different port values.
            best,
            • kurikoK Offline
              kuriko @sqbaczek
              @sqbaczek
              I think this might be some weird hardware problem, like a damaged component in the PaHUB causing the transmitted information to be incorrect... etc. Maybe the best way is to find a working one to test it.
              • E Offline
                Elliptic3612 @sqbaczek
                Greetings everyone! I have very similar error as @sqbaczek when running 1 ToF4M via PaHUB2 with CoreS3 and also Cardputer on UIflow 2.0. The ToF4M works fine when directly connected to the I2C port of either CoreS3 or Cardputer. It appears that ToF4M cannot be initiated when connected via PaHUB2 on UIflow 2.0.
                Below is the error I get with CoreS3 when on UIflow 2.0:
                  File "<stdin>", line 24, in <module>
                  File "<stdin>", line 17, in setup
                  File "driver/vl53l1x.py", line 60, in __init__
                Below is my code on UIflow 2.0:
                import os, sys, io
                import M5
                from M5 import *
                label0 = None
                i2c0 = None
                pahub_0 = None
                tof4m_0 = None
                def setup():
                  global label0, i2c0, pahub_0, tof4m_0
                  M5.begin()
                  label0 = Widgets.Label("label0", 0, 0, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                  i2c0 = I2C(0, scl=Pin(1), sda=Pin(2), freq=100000)
                  tof4m_0 = TOF4MUnit(PAHUBUnit(i2c=i2c0, channel=0), 0x29)
                def loop():
                  M5.update()
                  label0.setText(str(tof4m_0.get_distance))
                  try:
                    setup()
                    while True:
                      loop()
                    try:
                      print_error_msg(e)
                    except ImportError:
                I tested other units via PaHUB2 with CoreS3 on UIflow 2.0. These include Gesture Unit, 8Servos Unit, ENV Pro Unit, EXT.IO2 Unit. They all appear to work fine, at least not showing any initiation error.
                  SB12345 @Elliptic3612
                  My first post here. Came across this thread googling.
                  I can recreate this problem, it has been driving me crazy. I have tried 2 different PAHubs to ensure that isn't the issue. Can confirm the same issue arises with both. I bought the PAHub as it claimed it could handle 2 devices with the same I2C address across different ports, but something strange is occurring.
                  I have ToF4m sensors affixed 90 deg to each other, and attached to port A of a Core2 via the PAHub.
                  Either ToF4m works fine when it is the only unit connected to the Core2.
                  When both are connected via the PAHub, the results seem to interfere with each other. Particularly, a zero reading on one sensor always leads to a zero on the other. Also, the readings go from being stable and consistent to very noisy indeed - errors of up to 1m. I do not believe this is a laser intereference issue as if I cover one sensor, and point the other to clear air with no object for 3m, I still get a reading of 0 from both sensors.
                  I am also unable to initiate ToF4M when connected via PaHUB2 on UIflow 2.0, and have had to revert to 1.0 to perform these tests.
                  This has cost me a lot of time, and sadly I am unable to offer a solution at this time but I watch this thread with interest.
                  Edit to add:
                  If I remove one of the ToF4M modules whilst the program is running, both labels continue to update with results, further leading me to believe this is an address collision issue rather than a laser interference issue.
                    felmue @SB12345
                    Hi guys
                    BTW: TOF4m allows to change its I2C address (using set I2C address block in UIFlow2) so you could change the I2C address of one TOF4m, then connect both using a passive hub. This would take PaHub out of the equation.
                      SB12345 @felmue
                      @felmue Tried this. I could not get the address change to 'stick' after a power cycle, but perhaps I'm missing something. I did this using UIFlow2.
                        felmue @SB12345
                        Hello @SB12345
                        ok, I see, hmm.
                        Have you tried to connect one TOF4m to port A and the other to port C and then setup two I2C busses?
                          SB12345 @felmue
                          Indeed yes, I get a port address error. I have a Core 2.
                            felmue @SB12345
                            Hello @SB12345
                            ok, have you tried to only connect one TOF4m to port C? Does that work?
                              matthewchan @felmue
                              I have the same issue.
                              I tried to only connect only ONE TOF4m to PA.HUB 2.1 then Port A.
                              I got " unexpected arguement 'addrsize' " when I init TOF4M
                              but if i change TOF4M to TOF, it works fine(the init funtion of TOF, not 4M version, has no argument, i.e. just init() )
                              • kurikoK Offline
                                kuriko
                                @Elliptic3612 @matthewchan @SB12345 @sqbaczek
                                We have fixed this problem, please wait for the next version of UiFlow2 firmware
