    WiFi Channels, Deep Sleep Glitches & NB-IoT Workarounds | M5Stack Dev Diary
    1 Posts 1 Posters 641 Views 1 Watching
    • Y Offline
      yuyun2000
      Hey Makers! 👋
      We've been digging through some interesting edge cases that came up in the community recently—ranging from HID keyboard quirks on Tab5 to button debouncing on Cardputer, and even a gnarly UART issue with the NB-IoT2 Unit. If you've been scratching your head over any of these, here's what we found. Let's dive in! 🛠️
      01 | Tab5: Parsing Special Keys in BLE HID Keyboards
      Product: Tab5 (C145/K145)
      Category: Bluetooth / HID Protocol
      The Issue:
      You've got a BLE keyboard connected to your Tab5, and basic alphanumeric keys work fine—but arrow keys and function keys (F1-F12)? Nothing. Radio silence.
      Why This Happens:
      Standard HID keyboard reports use distinct key code ranges for special keys. Function keys live in 0x3A-0x45, and arrow keys hang out in 0x4F-0x52. If your parsing logic only handles the basic alphanumeric range, these guys get ignored.
      The Fix:
      Add the special key codes and extend your HID report parser:
      // Function keys (F1-F12)
      #define HID_KEY_F1  0x3A
      #define HID_KEY_F12 0x45
      // Arrow keys
      #define HID_KEY_ARROW_UP    0x52
      #define HID_KEY_ARROW_DOWN  0x51
      #define HID_KEY_ARROW_LEFT  0x50
      #define HID_KEY_ARROW_RIGHT 0x4F
      Then, in your HID input handler:
      void onInputReport(uint8_t reportId, uint16_t connHandle, uint8_t* data, uint16_t len) {
        if (len < 8) return;
        uint8_t keyCodes[6] = {data[2], data[3], data[4], data[5], data[6], data[7]};
        for (int i = 0; i < 6; i++) {
          if (keyCodes[i] == 0) continue;
          // Handle function keys (F1-F12)
          if (keyCodes[i] >= HID_KEY_F1 && keyCodes[i] <= HID_KEY_F12) {
            int fKeyNum = keyCodes[i] - HID_KEY_F1 + 1;
            M5.Display.printf("[F%d]", fKeyNum);
          // Handle arrow keys
          else {
            switch(keyCodes[i]) {
              case HID_KEY_ARROW_UP:    M5.Display.print("[UP]"); break;
              case HID_KEY_ARROW_DOWN:  M5.Display.print("[DOWN]"); break;
              case HID_KEY_ARROW_LEFT:  M5.Display.print("[LEFT]"); break;
              case HID_KEY_ARROW_RIGHT: M5.Display.print("[RIGHT]"); break;
      Pro Tips:
      • HID key codes follow the USB HID Usage Tables spec—keyboard vendors stick to this religiously.
      • Arrow and function keys are not affected by modifier keys (Shift, Ctrl, etc.). No combo handling needed here.
      • Want to add Home/End/PageUp? They're in 0x4A-0x4E. Same approach.
      • Media keys (volume, play/pause) live in a separate Consumer Control report (UUID 0x0C). That's a whole different beast.
      02 | Cardputer-Adv: Debouncing the Dual Button Unit
      Product: Cardputer-Adv (K132-Adv) / Dual Button Unit (U025)
      Category: Sensor / Signal Processing
      The Issue:
      You're reading button states directly from GPIO, and it's chaos. One press registers as three. One release registers as five. You're going insane.
      Why This Happens:
      Mechanical buttons are analog demons. When you press or release, the contacts bounce for 5-50ms, creating electrical noise that looks like multiple rapid presses to your microcontroller. Polling GPIO directly = you get all that noise.
      The Fix:
      Use M5Unified's Button_Class. It handles debouncing in software, so you get clean, stable events.
      Step 1: Initialize your buttons with debounce thresholds.
      #include <M5Unified.h>
      #define BLUE_BTN_PIN 1  // G1 = Blue button
      #define RED_BTN_PIN  2  // G2 = Red button
      m5::Button_Class blueBtn;
      m5::Button_Class redBtn;
        M5Cardputer.begin();
        // Set debounce time (20ms is a sweet spot for most buttons)
        blueBtn.setDebounceThresh(20);
        redBtn.setDebounceThresh(20);
        // Bind to GPIO (false = button is LOW when pressed)
        blueBtn.begin(BLUE_BTN_PIN, false);
        redBtn.begin(RED_BTN_PIN, false);
      Step 2: Check for stable events in your main loop.
        M5Cardputer.update();
        blueBtn.update();  // Internal debounce sampling
        redBtn.update();
        // Detect press (fires once)
        if (blueBtn.wasPressed()) {
          Serial.println("Blue Button Pressed");
        // Detect release
        if (redBtn.wasReleased()) {
          Serial.println("Red Button Released");
        // Detect click (full press + release)
        if (blueBtn.wasClicked()) {
          Serial.println("Blue Button Clicked");
        delay(5);
      Available Debounced Events:
      • wasPressed() — Fires once on press
      • wasReleased() — Fires once on release
      • wasClicked() — Fires once after a full press-and-release
      • isPressed() — True while held down
      • wasHold() — Fires after a long press (threshold configurable with setHoldThresh(ms))
      Pro Tips:
      • Keep debounce thresholds between 20-50ms. Too low = noise slips through. Too high = sluggish response.
      • The Dual Button Unit already has 10kΩ hardware pull-ups. Don't use INPUT_PULLUP.
      • Button_Class uses continuous sampling to confirm state stability—way better than a simple delay().
      • Default long-press threshold is 1000ms. Adjust with setHoldThresh() if needed.
      03 | StamPLC: Direct UART Control for NB-IoT2 Unit (SIM7028)
      Product: StamPLC (K141) / NB-IoT2 Unit (U118)
      Category: Compilation Error / Library Compatibility
      The Issue:
      You're using UIFlow 2.3.8 firmware on StamPLC, and the NBIOT2Unit class throws an AttributeError when you try to call execute_at_command() or execute_at_command2(). You can't even send a basic AT command to configure the APN.
      Why This Happens:
      Early StamPLC firmware (<2.4.0) shipped with a broken NBIOT2Unit driver. The method signatures were misaligned—the library expected some internal data structure instead of strings or tuples. This is fixed in later firmware, but there's no official update path yet for 2.3.8 users.
      The Workaround:
      Bypass the buggy library entirely. Talk to the SIM7028 module directly over UART2 using Arduino's HardwareSerial.
      Step 1: Initialize UART2 with StamPLC's Port C pins.
      #include <M5StamPLC.h>
      #include <HardwareSerial.h>
      // Port C mapping: RX=GPIO16, TX=GPIO17
      HardwareSerial sim7028Serial(2);
        M5StamPLC.begin();
        Serial.begin(115200);  // Debug output
        sim7028Serial.begin(115200, SERIAL_8N1, 16, 17);  // Init UART2
        delay(2000);
      Step 2: Create an AT command helper.
      String sendATCommand(String cmd, int timeout = 1000) {
        sim7028Serial.print(cmd + "\r\n");  // SIM7028 requires \r\n
        long start = millis();
        String response = "";
        while (millis() - start < timeout) {
          if (sim7028Serial.available()) {
            response += sim7028Serial.readString();
        return response;
      Step 3: Test basic AT commands.
        // Basic comms test
        Serial.println(sendATCommand("AT"));  // Should return "OK"
        // Signal strength
        Serial.println(sendATCommand("AT+CSQ"));  // Returns +CSQ: <rssi>,<ber>
        // Network registration status
        Serial.println(sendATCommand("AT+CEREG?"));  // +CEREG: 0,1 = registered
        delay(5000);
      Step 4: Configure APN and activate network (full flow).
      // Set APN (replace with your carrier's APN)
      sendATCommand("AT+CGDCONT=1,\"IP\",\"telstra.m2m\"");
      delay(1000);
      // Activate PDP context
      sendATCommand("AT+CGACT=1,1");
      delay(2000);
      // Attach to GPRS network
      sendATCommand("AT+CGATT=1");
      delay(5000);
      // Verify IP address assignment
      Serial.println(sendATCommand("AT+CGPADDR=1"));
      Pro Tips:
      • StamPLC's Port C uses UART2 with fixed pins: RX=16, TX=17. No remapping allowed.
      • SIM7028 requires \r\n line endings. Without them, commands are ignored.
      • Signal strength (CSQ) ranges from 0-31. (99 = unknown). You want ≥10 before trying to attach.
      • Network registration can take 5-30 seconds. AT+CEREG? returning +CEREG: 0,1 means success.
      • This approach also works in UIFlow 2's MicroPython environment—just swap HardwareSerial for machine.UART.
      • LED indicators: Blue LED blinking = searching for network. Solid = connected. Off = module unpowered or dead.
      💬 Discussion
      Have you run into similar gotchas with HID parsing, button debouncing, or cellular modules? Drop a comment below or share your own workarounds! We'd love to hear how you're tackling these issues in the wild.
      📌 Resources
      • 📚 Docs: https://docs.m5stack.com
      • 🗣️ Forum: https://community.m5stack.com
      • 🛒 Shop: https://shop.m5stack.com
      Note: This series shares common troubleshooting tips from the M5Stack engineering desk. All user data has been anonymized.
