    Bottom2 and M144 ES8388 Audio Module I2S Bus Conflict
    Scheduled Pinned Locked Moved Features Wish List
    1 Posts 1 Posters 19 Views
    • Y Offline
      YO3HJV
      Please, add a switch on Bottom 2 to disconnect the SPM1423 I2S lines or to switch the ENABLE pin to solve the I2S Bus conflict.
      The Bottom2 module includes a SPM1423 MEMS microphone, which uses:
      GPIO0 (BUS pin 24) for the clock signal (CLK)
      GPIO34 (BUS pin 26) for the data signal (DAT, digital output)
      The Audio Module, based on the ES8388 codec, uses:
      GPIO0 (BUS pin 24) for I2S_MCLK
      GPIO34 (BUS pin 26) for I2S_MAIN_DIN
      This creates a fundamental hardware conflict on the I2S bus.
      The Core Conflict
      Two independent devices attempt to drive the same data line:
      The ES8388 (M144 Audio Module) uses GPIO34 to send digitized audio data from its ADC (line-in or microphone) to the ESP32 via I2S.
      The SPM1423 (Bottom2) uses the same GPIO34 to output PDM audio data from its internal MEMS microphone.
      More about this here: I2S Bus Conflict Between M5Stack Core2 Audio Module and Bottom2
      Thank you,
      Adrian
