    Wifi with user name
    7 Posts 2 Posters 12.8k Views 1 Watching
      hetzer
      My wifi setup requires user name and a password to be entered. Uiflow firmware is just asking for password, there is no input for username? How can I connect my M5fire in such setup?
      • lukasmaximusL Offline
        When you connect to your wifi on a mobile or desktop device does a webpage appear asking you to input username and password to connect? If its a portal the only way to get around it would be to connect a computer, preferably something like a raspberry pi and create a seperate access point from that device
          hetzer
          My connection does not lead to me a portal but it is WPA-Enterprise requesting both a user name and password.
            currently there is no way to use m5stack with wpa-enterprise. Perhaps you could change your routers settings by entering its ip address in your browser, its usually something like 192.168.1.1, 192.168.1.2, 192.168.1.0 etc.. depending on your router manufacturer
              hetzer @lukasmaximus
              @lukasmaximus Thanks Lukas. Created a mobile wifi and tethered usb connection. Now it works. Sometimes it requires couple of tried to upload the code but it is ok.
                @hetzer sorry you had to use your mobile phones hotspot to get around it. We will look into the possibility of connecting to wpa-enterprise hotspots. For now if you are a windows or linux user you can download the offline version by going to m5stack.com then clicking explore>download>desktop ide
                  @lukasmaximus Thanks Lukas. I had posted in another subject. The desktop ide does not allow me to create variable. I see the icon put does not open the pop up screen to name the variable.
