    I'm going to play with BugC,
    8 Posts 2 Posters 13.9k Views 1 Watching
      tbe01025
      I have some troubles.
      • I2C command have no document (or Arduino sample is required)
      • M5StickC and BugC "BAT" pin conflict
      If there is a solution, I'm happy.
      • m5stackM Offline
        hi , the "BAT" pin was not conflict. the BugC Arduino example at present we not provide.
          tbe01025 @m5stack
          @m5stack
          Thank you.
          I found the motor control similar to "BeetleC".
          I don't know if it is correct.
          M5StickC screen is confused when a battery is inserted into BugC.
          Is there any reverse flow from the battery on BugC side to the BAT output of M5StickC?
          • m5stackM Offline
            m5stack @tbe01025
            @tbe01025 could you check out your battery direction is it right or not
              tbe01025 @m5stack
              @m5stack
              Thanks,
              It matches the markings on the battery box.
              If I get another M5StickC,I try again.
                tbe01025
                Tried again.
                Insert the BugC battery and turn on power.
                On another M5StickC, screen blacked out.
                It seems that the problem has been solved by extending the pin socket and removing only the BAT pin.
                How about BugC's BAT connected to 5VIN of M5StickC.
                But requires 16340 charger.
                The LED control method is unknown.
                  tbe01025 @tbe01025
                  @tbe01025 Thanks, the Arduino sample code.
                  • m5stackM Offline
                    m5stack @tbe01025
                    @tbe01025
                    BugC Arduino Example
                    Github:https://github.com/m5stack/M5StickC/tree/master/examples/Hat/BUGC
