  • Firmware menu loop
  • UIFlow2 burn fails on m5burner 3.0.0
    3k Views
  • pls help there is no com
    robskiR
    install drivers, check with few usb cables as some are power cables only not data cables, was your M5Gray supplied with cable?
  • HardwareSerial ss(2)? UART connection on 16/17 for a GPS Antenna
    8
    17k Views
    C
    @Andrzej-Sailing Thank you for Sharing!!! this helped me tremendously!
  • How to power the M5stack Grey apart from USB-C and battery?
    3k Views
    felmueF
    Hello @alcor please have a look at the schematic. With external 5 V you can power the M5Stack Gray either through the IO Port or the Bus Port. Use pins 5 V and GND (G). No, when powering the M5Stack with external 5 V, the battery will not be charged as this bypasses the TP5306 charger IC. Thanks Felix
  • Motordriver L298N with M5core ?
    5k Views
    T
    Thanks @teastain, i try it since few days, but i can't find any information how i must connect the Motor Modul. I use this one: Link Have you an idea how i must connect ENA (for PWM), IN1 and IN2 with the M5stack core and set the motor speed with PWM?
  • Core ESP32 operating temperature?
    7
    10k Views
    A
    Hi all! I figured I'd update this thread with my findings. I've been running a unit in my non-insulated plastic shed for two months of Canadian winter with no problems whatsoever. The screen turned on immediately and is perfectly fine. No unexplained lockups, reboots, or other glitches. It has been a relatively warm winter (unfortunate for my testing). Inside the shed, it got down to -15C one weekend, but for the rest of the time, it has been between 0C and -6C. Humidity has been an average of 78% with a peak at 97%.
  • No reset when USB power removed [SOLVED]
    13
    33k Views
    J
    Can confirm the m5stack core2 aws iot edukit edition suffers this same behavior. I don't trust myself to do the tiny soldering, this is incredibly disappointing.
  • This topic is deleted!
  • Can the image in UIFlow be rotated?
    4k Views
  • M5 Timer Cam Reset button
    4k Views
    felmueF
    Hello @jsolo12345 the reset button only restarts the ESP32. The EEPROM is emulated on most devices *) and simply a part of the flash. In other words, no, the content of the EEPROM is not deleted when the reset button is pressed. It gets erased however when the flash chip is erased, but then the program is gone as well. *) M5Paper is an exception as it actually has a dedicated EEPROM IC. Thanks Felix
  • no module named m5stack_ui
    6
    13k Views
    J
    This worked for me... https://community.m5stack.com/topic/3861/solved-importerror-no-module-named-m5stack_ui
  • M5Stack Core Firmware getting lost
    3k Views
  • M5stack Grey + GoPlus2
    4k Views
  • M5stack Grey + M5GO bottom
    7
    16k Views
    C
    @calvorotas I'm having similar issues. What is that "adjust all pins" about? Did you had any bent pins? My 15x2 looks good, but I'm unsure what does "adjust" mean and maybe I have to do something. Thanks!
  • Log events on SD card and OneWire
    6k Views
    F
    @felmue thank you Felix, that is very helpful and explains. Will check out other pin. Thanks!
  • M5stack and DS18B20
    7k Views
    F
    @felmue thank you very much for your help!
  • Random shutdown while battery is still charged
    5k Views
  • only 1 working stepper motor out of the 2
    7k Views
    B
    i fixed it now turned out the cable cracked while setting evrything up. so it just didnt see the second engine anymore.
