  • LVGL performance problem
    3k Views
    S
    @俺がガンダムだ said in LVGL performance problem: I applied LVGL on stickc-plus2,with TFT_eSPI's st7789v2 driver.But the refreshing rate is very low (while doing "load screen anim").I know stickc had good performance on drawing screen (by watching the video of M5stick T-Lite Thermal tutorial). And the LVGL also has a good performance through Dial-ESP32-S3 and Din-Meter demonstration video. So what is the reason of such low performance. Cound it be the TFT_eSPI library? I’ve seen similar issues on the StickC-Plus2. It could be due to TFT_eSPI settings, try increasing the SPI frequency or enabling DMA. Also, check your LVGL buffer config; full buffering helps with performance.
  • first approach on Squareline Studio - M5Dial
    1 Votes
  • using lvgl+squareline studio+m5dial
    4 Votes
    3k Views
    S
    @khlmlutrija Hi , could you post your setup files ? and/or specific tips done to get it working the LCD? I tried it but can only get sort of yellow/white screen with rubbish on it.
  • M5Dial + Arduino + LVGL
    3k Views
    robskiR
    @gmnvh I reccomend to look in to "volos" projects on YT
  • lvgl on m5sack cores3
    9
    7k Views
    @robski yes the simple use example I have used before
  • LVGL Version number?
    Moved
    3k Views
    ajb2k3A
    @felmue Thanks, my brain had collapsed I see a few comments on Squareline studio and so looking at it.
