    GoPlus motor rotates only one direction
    goplus
    1 Posts 1 Posters 4.3k Views
    • N Offline
      Nabeshin
      I'm trying to control 130RA motors using GoPlus (not GoPlus2).
      But it rotates only one direction.
      Anyone have same problem??
      I'm using,
      • GoPlus controlled with M5Stack Fire
      • 130RA motors( https://akizukidenshi.com/download/ds/mercurymotor/FA-130RA-2270_20190306.pdf )
      • External stabilized power supply 5.5V
      My Investigation are following.
      I uploaded this simple code to my GoPlus module.
      //GoPlus Motor Debug code for Atmega328
      const int IN_0 = 9;
      const int IN_1 = 10;
      const int IN_2 = 11;
      const int IN_3 = 3;
        pinMode(IN_0, OUTPUT);
        pinMode(IN_1, OUTPUT);
        pinMode(IN_2, OUTPUT);
        pinMode(IN_3, OUTPUT);
        digitalWrite(IN_0, LOW);
        digitalWrite(IN_1, LOW);
        digitalWrite(IN_2, LOW);
        digitalWrite(IN_3, LOW);
        delay(2000);
        digitalWrite(IN_0, HIGH);  //M0  ---NG--------
        digitalWrite(IN_2, HIGH);  //M2  --OK: but rotates Intermittently--
        delay(2000);
        digitalWrite(IN_1, HIGH);
        digitalWrite(IN_3, HIGH);
        delay(2000);
        digitalWrite(IN_0, LOW);   //M0  --OK: but rotates Intermittently--
        digitalWrite(IN_2, LOW);   //M2  --NG--------
        delay(2000);
        delay(2000);
        digitalWrite(IN_0, LOW);   //M0  --OK: rotates Continuously--
        digitalWrite(IN_2, HIGH);  //M2  --OK: rotates Continuously--
        delay(2000);
      Only following case works well, but others don't...
        digitalWrite(IN_0, LOW);   //M0  --OK--
        digitalWrite(IN_2, HIGH);  //M2  --OK--
      • The voltage(HIGH / LOW) of IN_0 to IN_3 of LV8548 are correct for all cases.
      • I replaced to another GoPlus module, but it was exactly the same.
      To drive 130RA motor, GoPlus is too weak??
