    Drawing random PNG images from SD problem
    4 Posts 2 Posters 8.6k Views
      AndyT
      How do i get this code to work
      this works :
      M5.Lcd.drawPngFile(SD,"/Image8.PNG", 0, 0); // display splash screen
      but
      M5.Lcd.drawPngFile(SD,PngName, 0, 0); // display splash screen
      does not in code below.
      I want to generate a random slide show
         int Arand=random(11);
        String PngName="/Image"+ String (Arand)+".PNG";
        Serial.println (PngName);
         M5.Lcd.drawPngFile(SD,(PngName), 0, 0); // display splash screen
        Hi @AndyT
        AFAIK drawPngFile() expects a pointer to a character array as path name and not a String. Just curious, does your code compile w/o error?
        I think something like this should work:
        M5.Lcd.drawPngFile(SD, PngName.c_str(), 0, 0);
          AndyT
          Cheers Felix,
          No it did not compile without errors before. But adding .c.str() solved it .
          Thank you again
            Hello @AndyT
            you are welcome. Glad to hear it works now.
            Cheers
