    FATAL ERROR: Name m5line is not defined
    1 Posts 1 Posters 4.3k Views 1 Watching
    • sysdl132S Offline
      sysdl132
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import unit
      setScreenColor(0x514f4f)
      earth0 = unit.get(unit.EARTH, unit.PORTA)
      std = M5Circle(40, 91, 10, 0xFFFFFF, 0xFFFFFF)
      text0 = M5TextBox(61, 119, "Status", lcd.FONT_Default, 0x78ff00, rotate=180)
      text1 = M5TextBox(77, 149, "Water monitor", lcd.FONT_DefaultSmall, 0x00e5ff, rotate=0)
      label0 = M5TextBox(77, 58, "value:", lcd.FONT_Default, 0xe4ff00, rotate=180)
      rectangle0 = M5Rect(2, 41, 34, 20, 0xFFFFFF, 0xFFFFFF)
      angread = M5TextBox(30, 57, "err", lcd.FONT_DefaultSmall, 0x000000, rotate=180)
      rectangle1 = M5Rect(16, 11, 20, 20, 0xFFFFFF, 0xFFFFFF)
      label1 = M5TextBox(77, 27, "Unit std:", lcd.FONT_DefaultSmall, 0xfffe00, rotate=180)
      line0 = M5Line(M5Line.PLINE, 16, 128, 62, 128, 0xFFFFFF)    # <--bug line
      need = M5TextBox(75, 74, "Water needed!", lcd.FONT_DefaultSmall, 0xff0000, rotate=180)
      # sysinit
      def init():
        need.hide()
        angread.setText('0')
        rectangle0.setBgColor(0xff0000)
        rectangle0.setBorderColor(0xff0000)
        std.setBgColor(0xff0000)
        std.setBorderColor(0xff0000)
      init()
      while True:
        if False:
          angread.setText(str(earth0.analogValue))
        elif False:
          pass
        wait_ms(2)
      For Atom:115200/230400/921600
