    51 Posts 14 Posters 360.4k Views 7 Watching
      Calin @Kryten
      @kryten
      • If your router don't support WPS, you can use the SmartConfig app on the phone to connect the M5Stack to Wifi
      • Weather settings are already implemented. Read the project description.
        At the Weather Station chapter you can find info about WeatherParams.txt file and how to use it.
        Kryten @Calin
        @calin Yes I saw this after I postede, sorry.
        This is really good work by the way ;)
        • 1nformatica1 Offline
          1nformatica
          Hi All, I have just uploaded a video review of the Apps to Youtube Apps Review
          I made a silly mistake with the oscilloscope App as of course it cannot handle negative going inputs!!
            Calin @1nformatica
            @1nformatica You didn't apply the PlatformIO patch and you are getting the BtnA (left key) unwanted "presses".
            M5Stack use GPIO39 for BtnA.
            There is a bug on arduino-esp32 framework that cause interference between Wifi and GPIO39.
            That patch contain arduino-esp32 precompiled libraries that don't have this bug.
            Since the libraries came precompiled, i don't have access to the code to find what's causing that bug and fix the problem.
            • KabronK Offline
              Kabron
              Hello, Calin,
              I allowed myself a tiny mod to your App. Now it can be launched from the SD card under SD-Menu from tobozo. https://github.com/tobozo/M5Stack-SD-Updater.
              Modification consists in main.c mod and extra libraries. Just unzip Matroska.zip to project folder and build. Resulting firmware.bin in .pioenvs\m5stack-core-esp32
              is compatible with tobozo loader.
              Zip here:
              https://yadi.sk/d/8sroLeG_3YMfwe
                Calin @Kabron
                @kabron you can do that if you whant for your M5Stack.
                @tobozo can make a repository that contain this mods too.
                I won't do that because i need every bit of flash memory for the apps that i am working on...
                I just updated MultiApp.
                • Added Tetris game with score and high score counter.
                • Fixed some bugs related to fonts
                Getting closer to flash size limit...
                • KabronK Offline
                  Kabron @Calin
                  @calin 在 M5Stack MultiApp Advanced Firmware 中说:
                  With one tiny exception:
                  Tobozo's app does not restart menu with BtnA+Reset
                    picpic020960
                    sad that the pre-compiled firmware is no longer available.
                    when will he come back
                    thanks
                      Calin @picpic020960
                      @picpic020960 在 M5Stack MultiApp Advanced Firmware 中说:
                      thanks
                      Install VsCode, PlatformIO, then flash the project to M5Stack.
                      Is a straight forward procedure.
                      I removed the pre-compiled firmware because the M5Stack had to be formatted with a specific partition table for pre-compiled firmware to work.
                        picpic020960
                        no is straight forward with corporate proxy !
                        old version of pre-compiled firmware work fine.
                        why partition issue ?
                        [pre-compiled firmware is best for MultiApp popularity]
                        thanks
                          Calin @picpic020960
                          Well... yeah... you are right on this one...
                          thanks
                          Ok... i will bring it back later today...
                            picpic020960
                            Hi Calin
                            tested last night ! sync , download , finish , reset and ... black screen
                            maybe my error : use the old [not Advanced] FLASH_DOWNLOAD_TOOLS_V3.6.4.zip
                            other way : 'old MultiApp' is OK without SD card and no jpg , maybe 'Advanced' no ?
                            more : windows 10 (on thomson tablet)
                            my fear :have bad clone !
                            I test again tonight
                            Regards
                              Calin @picpic020960
                              Hi Calin
                              Regards
                              As i told you... the best solution is to COMPILE the project on PlatformIO.
                              The M5Stack came with default factory partitions table.
                              That partition table is incompatible with MultiApp-Advanced firmware.
                              Old MultiApp firmware use standard partitions table and that's why that precompiled binary work.
                              The precompiled firmware only write the application data. So precom piled binary will be useful only if you try to update the multiapp-advanced firmware to a newer version.
                              Will NOT work if you try to write the multiapp-advanced over a different application.
                              On MultiApp-advanced i use a custom partition table that is written if you compile and upload the project from PlatformIO.
                                picpic020960
                                Hi Calin , OK
                                Download (and unzip) this repository ==> OK
                                Download and Install Visual Studio Code https://code.visualstudio.com/ ==>OK
                                Install the PlatformIO Extension ==> OK
                                Install ESP32 Framework on PlatformIO ==> How TO ? no link and a lot of ESP32 framework
                                thanks for help
                                Regards
                                  Calin @picpic020960
                                  Hi Calin , OK
                                  thanks for help
                                  Regards
                                  Go to Platforms
                                  Type in ESP32 on the search bar
                                  Click on Espressif 32
                                  Click INSTALL
                                  Wait to finish (this may take 1 - 5 minutes, depending on your internet connection speed)
                                  Done.
                                  To open MultiApp Advanced project:
                                  right click on the project folder
                                  Select "Open in VsCode"
                                  VsCode will open and the project will be loaded in PlatformIO
                                  You don't need to install any library to compile the MultiApp-Advanced. All necessary resources are included into project.
                                    picpic020960
                                    Calin
                                    first compil :
                                    src\Apps\WiFiWps\WpsConnect.cpp:73:16: error: no match for 'operator=' (operand types are 'esp_wps_config_t' and '<brace-enclosed initializer list>')
                                    some mistake ?
                                    edit :
                                    commented ==> Build OK
                                    but how to load the firmware in the m5stack ?
                                    other question : how to apply the patch ?
                                    thanks for help
                                    Regards
                                      Calin @picpic020960
                                      Calin
                                      first compil :
                                      some mistake ?
                                      No. There is no mistake.
                                      PlatformIO updated the Arduino-ESP32 framework to new version.
                                      I updated the MultiApp firmware to work with this new version.
                                      If you use git, just pull the latest commit from github and recompile.
                                      If not, download the repository again then compile.
                                      edit :
                                      Please READ the repository instructions !
                                      The old patch is no longer needed... because Espressif fixed the GPIO39 bug on the latest arduino-esp32 framework.
                                        picpic020960
                                        Hi Calin
                                        when m5stack not connected i see ' <version....py>' at end of build report.
                                        (from memory , now at work , not at home)
                                        when m5stack connected i see nothing at end of build report.
                                        i have com1 and com4. how to choose ?
                                        thanks for help
                                        Regards
                                          Calin @picpic020960
                                          Hi Calin
                                          thanks for help
                                          Regards
                                          You don't have to chose anything.
                                          No need to select the upload port.
                                          PlatformIO will detect the M5Stack port automatically, once is connected to PC USB.
                                          • KabronK Offline
                                            Kabron
                                            New version compilation results:
                                            M5StackMod initializing...[E][sd_diskio.cpp:739] sdcard_mount(): f_mount failed 0x(3)
                                            E (705) SPIFFS: mount failed, -10025
                                            [E][SPIFFS.cpp:47] begin(): Mounting SPIFFS failed! Error: -1
                                            OK
                                            [E][Preferences.cpp:330] getUShort(): nvs_get_u16 fail: light NOT_FOUND
                                            and nothing more...
                                            any ideas?
