Check your uPython version
from m5stack import * from m5ui import * from uiflow import * import time import uos setScreenColor(0x000000) vstart = None vsysinfo = None vsecs = None vmins = None vtimetext = None battery = M5TextBox(0, 0, "loading", lcd.FONT_DejaVu18, 0xFFFFFF, rotate=0) uptime = M5TextBox(0, 32, "loading", lcd.FONT_DejaVu18, 0xFFFFFF, rotate=0) lb_sysinfo = M5TextBox(0, 64, "loading", lcd.FONT_DejaVu18, 0xFFFFFF, rotate=0) import math lcd.setBrightness(10) vstart = time.ticks_ms() vsysinfo = uos.uname() lb_sysinfo.setText(str(vsysinfo)) while True: battery.setText(str((str(((str('Battery: ') + str((power.getBatteryLevel()))))) + str('%')))) vsecs = round(((time.ticks_ms()) - vstart) / 1000) vmins = math.floor(vsecs / 60) vtimetext = (str((vsecs % 60)) + str('s')) if vmins != 0: vtimetext = (str(((str(vmins) + str('m ')))) + str(vtimetext)) vtimetext = (str('Uptime: ') + str(vtimetext)) uptime.setText(str(vtimetext)) wait_ms(2) -
Interesting, when executing on a M5Stack Core2 via REPL I get an error message:
Traceback (most recent call last): File "<stdin>", line 21, in <module> AttributeError: 'TFT' object has no attribute 'setBrightness' -
I would prefer to have a stable API for all devices. Current situation makes re-use of code complicated.
Someone could write a wrapper API to cover the differences ;-)
I'm trying to push for a unified API but the problem is that some of the devices are slightly different and require slightly different commands.
Please add your request for a unified API to the suggestions list.
