    51 Posts 14 Posters 359.7k Views 7 Watching
      picpic020960
      Hi Calin , OK
      Download (and unzip) this repository ==> OK
      Download and Install Visual Studio Code https://code.visualstudio.com/ ==>OK
      Install the PlatformIO Extension ==> OK
      Install ESP32 Framework on PlatformIO ==> How TO ? no link and a lot of ESP32 framework
      thanks for help
      Regards
        Calin @picpic020960
        @picpic020960 在 M5Stack MultiApp Advanced Firmware 中说:
        Hi Calin , OK
        thanks for help
        Regards
        Go to Platforms
        Type in ESP32 on the search bar
        Click on Espressif 32
        Click INSTALL
        Wait to finish (this may take 1 - 5 minutes, depending on your internet connection speed)
        Done.
        To open MultiApp Advanced project:
        right click on the project folder
        Select "Open in VsCode"
        VsCode will open and the project will be loaded in PlatformIO
        You don't need to install any library to compile the MultiApp-Advanced. All necessary resources are included into project.
          picpic020960
          Calin
          first compil :
          src\Apps\WiFiWps\WpsConnect.cpp:73:16: error: no match for 'operator=' (operand types are 'esp_wps_config_t' and '<brace-enclosed initializer list>')
          some mistake ?
          edit :
          commented ==> Build OK
          but how to load the firmware in the m5stack ?
          other question : how to apply the patch ?
          thanks for help
          Regards
            Calin @picpic020960
            Calin
            first compil :
            some mistake ?
            No. There is no mistake.
            PlatformIO updated the Arduino-ESP32 framework to new version.
            I updated the MultiApp firmware to work with this new version.
            If you use git, just pull the latest commit from github and recompile.
            If not, download the repository again then compile.
            edit :
            Please READ the repository instructions !
            The old patch is no longer needed... because Espressif fixed the GPIO39 bug on the latest arduino-esp32 framework.
              picpic020960
              Hi Calin
              when m5stack not connected i see ' <version....py>' at end of build report.
              (from memory , now at work , not at home)
              when m5stack connected i see nothing at end of build report.
              i have com1 and com4. how to choose ?
              thanks for help
              Regards
                Calin @picpic020960
                Hi Calin
                thanks for help
                Regards
                You don't have to chose anything.
                No need to select the upload port.
                PlatformIO will detect the M5Stack port automatically, once is connected to PC USB.
                • KabronK Offline
                  Kabron
                  New version compilation results:
                  M5StackMod initializing...[E][sd_diskio.cpp:739] sdcard_mount(): f_mount failed 0x(3)
                  E (705) SPIFFS: mount failed, -10025
                  [E][SPIFFS.cpp:47] begin(): Mounting SPIFFS failed! Error: -1
                  OK
                  [E][Preferences.cpp:330] getUShort(): nvs_get_u16 fail: light NOT_FOUND
                  and nothing more...
                  any ideas?
                    Calin @Kabron
                    @kabron 在 M5Stack MultiApp Advanced Firmware 中说:
                    OK
                    and nothing more...
                    any ideas?
                    Please update the Espressif 32 platform to latest version (v1.1.1 at this moment)
                    That should solve the problem.
                    • KabronK Offline
                      Kabron @Calin
                      @calin 在 M5Stack MultiApp Advanced Firmware 中说:
                      I have 1.1.2 installed and do not know how to degrade
                      P.S.
                      degrade with
                      platform = espressif32@1.1.1
                      and now it works
                        Calin @Kabron
                        P.S.
                        degrade with
                        and now it works
                        I just tested with espressif32 V1.1.2 and work's just fine.
                        Please download the latest repository commit and compile.
                        it should work just fine.
                          Rodlenz
                          Hi Calin, thanks for this amazing work. How I can add my own code/Application? Tks in advance for any help you can provide. brgds.
                          ? 1 Reply Last reply Reply Quote 0
                          • ? Offline
                            A Former User @Rodlenz
                            Hi
                            somebody make a test with Netatmo ?
                            I would like to be sure before start this install to see if there are possibility to connect via API key to netatmo server.
                            interest by this
                            Thx
                            • B Offline
                              brianbgarber
                              Hello, I realize this topic is very old but I'm trying to compile the MultiApp Advanced firmware. I'm getting several compile issues:
                              1. src/Apps/WiFiWps/WpsConnect.cpp:30:12: error: 'struct esp_wps_config_t' has no member named 'crypto_funcs'
                              2. src/Apps/WiFiWps/WpsConnect.cpp:30:28: error: 'g_wifi_default_wps_crypto_funcs' was not declared in this scope
                              3. src/Apps/WiFiWps/WpsConnect.cpp:90:27: error: no matching function for call to 'onEvent(void (&)(arduino_event_id_t, system_event_info_t))'
                              4. src/Apps/WiFiWps/WpsConnect.cpp:90:18: error: invalid conversion from 'void ()(arduino_event_id_t, system_event_info_t)' to 'WiFiEventSysCb' {aka 'void ()(arduino_event_t*)'} [-fpermissive]
                              5. *** [.pio\build\esp-wrover-kit\src\Apps\WiFiWps\WpsConnect.cpp.o] Error 1
                              6. lib/ESP32Audio/src/AudioOutputI2S.cpp:190:10: error: 'i2s_write_bytes' was not declared in this scope
                              7. *** [.pio\build\esp-wrover-kit\lib803\ESP32Audio\AudioOutputI2S.cpp.o] Error 1
                              I did clone the git repo today, so everything should be up to date. Looks like I'm missing some library?
                              Thanks,
                              Brian
