    M5Paper SDCard access
    10 Posts 8 Posters 19.8k Views 2 Watching
    • TitiMobyT Offline
      TitiMoby
      Is there a way to access M5Paper SD card with MicroPython?
      There is no uos module, but os has mount function.
      I tried:
      import os
      os.mount(machine.SDCard(), '/sd')
      which result in:
      OSError: 16
        mrk
        Did you ever figure this out? Struggling with the same issue
          Medy @mrk
          @mrk I figured it out...
          turns out you dont need to mount at all just do
          import json
          with open('/sd/config.json', 'r') as fs:
          c = json.loads(fs.read())
          label0 = M5TextBox(140, 106, c['ssid'], lcd.FONT_Default, 0xFFFFFF, rotate=0)
          I may have run some code prior to that .. dont remember .. try that if the first thing didnt work .. ( this is from boot.py) ... maybe it gets added automatically
          import machine, os
          try:
              sd = machine.SDCard(slot=3, miso=19, mosi=23, sck=18, cs=4)
              sd.info()
              os.mount(sd, '/sd')
              print("SD card mounted at \"/sd\"")
          except:
              pass
          import uos
          uos.sdconfig(uos.SDMODE_SPI,clk=18,mosi=23,miso=19,cs =4)
          uos.mountsd()
            paeber @Medy
            @medy which UIFlow version do you use? v1.9.0? I have the M5Paper (Version 1) with v1.9.0
            I've still got some issues but I'm glad that this topic still has some progress.
            The code you posted from boot.py is present on mine as well, but commented out. If I add the code (in boot.py or main.py) my device freezes. This happens on sd.info() and os.mount(sd, '/sd').
            Did you use your third code from the post? or is this just a regular micropython module?
            Any help is highly appreciated :)
              Pavlo
              Same problem. Any updates? There must be a reason why the code in boot.py is there and why it was commented out
                Hello guys
                the uncommented code in boot.py uses the incorrect SPI GPIOs for M5Paper. But even with the correct GPIOs it doesn't seem to work. I suspect that the SDCard driver built into the M5Paper UiFlow firmware is faulty.
                That said, I found a replacement SDCard driver here mentioned here that seems to work.
                With the sdcard.py file downloaded onto my M5Paper (alongside boot.py, main.py) I was able to list the files on the inserted SD card and write and read a file.
                import os
                from machine import Pin, SPI
                from sdcard import SDCard
                spisd = SPI(-1, miso=Pin(13), mosi=Pin(12), sck=Pin(14))
                sd = SDCard(spisd, Pin(4))
                os.mount(sd, '/sd')
                print(os.listdir('/sd'))
                ### Write file
                #f = open('/sd/___AAA.txt', 'w')
                #f.write('Some text')
                #f.close()
                ### Read a file
                #f = open('/sd/___AAA.txt', 'r')
                #print(f.read())
                #f.close
                Note: I was using Thonny to download and test.
                  Medy @felmue
                  @felmue said in M5Paper SDCard access:
                  os.mount(sd, '/sd')
                  Doesnt work for me ( it works for printing in thonny ... but the device freezes)
                    mehulge
                    This issue has returned for Ui Flow 2.
                    [Errno 22] EINVAL
                    E (705271) spi: spi_bus_initialize(758): SPI bus already initialized.
                    File "<stdin>", line 13, in <module>
                    File "<stdin>", line 8, in setup
                    File "hardware/sdcard.py", line 21, in sdcard
                    OSError: (-259, 'ESP_ERR_INVALID_STATE')
                    Any possible solutions?
                      Hello @mehulge
                      yep, still broken. And my previous attempt to fix that doesn't seem to work anymore.
                        rodrigob @felmue
                        @mehulge stuck with same issue, did you ever found the fix?
                        • R rodrigob referenced this topic on
