    M5 POWER BANK with IP5108
    6 Posts 4 Posters 25.5k Views 2 Watching
      JiKuch
      Under this link IP3506 AUTOMATIC STANDBY was discussed the M5 Power Bank module.
      Here is the inspiration from the realization of this module:
      1. Schema
      2. BOM
      3. PCB for hand soldering
      4. Case - 3D printed
      5. Final functional module
      M5 Power Bank with IP5108 fully replaces M5 BOTTOM:
      • The module also contains a magnet (big one)
      • External M-bus (fully) is on the right side (female 2x15)
      • LED indicator and On/Off button is on the left side
      • LED functionality can be selected (5V, On/Off=IRQ, GPIO00 or GPIO01 software control)
      • On/Off button functionality can also be programmed thru IP5108 registers
      WARNING:
      The module is designed to be connected directly to the M5 CORE because the components enter the space of M5 CORE!
        jfmateos
        Nice desing jikuch.... I am trying to adapt it for a solar powered system, but am unable to find information in english about the ip5108 i2c register.
        Could you help me?
          JiKuch @jfmateos
          IP5108 I2C description:
          7-bit slave address IP5108 is 0x75 (byte with write bit = 0xEA; byte with read bit = 0xEB)
          400 Kbps speed of I2C supported
          1 byte data = 8-bit data (bits from 7 to 0)
          WRITE Arduino example:
          Wire.beginTransmission(0x75);
          Wire.write(register_address_byte);
          Wire.write(data_byte);
          Wire.endTransmission();
          READ Arduino example:
          Wire.requestFrom(0x75,1);
          data_byte = Wire.read();
          REGISTERS:
          1. Enable / disable functions:
          SYS_CTL0 = 0x01:
          • bit 4 (read/write): 0 = disbale / 1 = enable (1 = after reset) detection ??? (I do not understand.)
          • bit 3 (read/write): 0 = disbale / 1 = enable (1 = after reset) light
          • bit 2 (read/write): 0 = disbale / 1 = enable (1 = after reset) booster
          • bit 1 (read/write): 0 = disable / 1 = enable (1 = after reset) charger
          SYS_CTL1 = 0x02:
          • bit 1 (read/write): 0 = disable / 1 = enable (1 = after reset) auto-standby
          • bit 0 (read/write): 0 = disable / 1 = enable (1 = after reset) auto ??? (I do not understand.)
          SYS_CTL3 = 0x03:
          • bit 5 (read/write): 0 = disable / 1 = enable (1 = after reset) off by button
          2. General setup features:
          SYS_CTL2 = 0x0C:
          • bits 7-3 (read/write): (01010 = after reset) auto-standby current limit as multiple 12 mA
          SYS_CTL4 = 0x04:
          • bits 7-6 (read/write): (10 = after reset) time for auto-standby: 00=8s, 01=16s, 10=32s, 11=64s
          SYS_CTL3 = 0x03:
          • bits 7-6 (read/write): (01 = after reset) time for recognition button press: 00=1s, 01=2s, 10=3s, 11=4s
          SYS_CTL5 = 0x07:
          • bit 1 (read/write): (0 = after reset) control of light by button: 0=press, 1=double click
          • bit 0 (read/write): (0 = after reset) off by button: 0=double click, 1=press
          3. Charging setup features:
          CHARGER_CTL1 = 0x22:
          • bits 3-2 (read/write): (01 = after reset) VOUT undervoltage limit during chargig: 00=4.53V, 01=4.63V, 10=4.73V, 11=4.83V
          CHARGER_CTL2 = 0x24:
          • bits 6-5 (read/write): (00 = after reset) battery type = charging voltage: 00=4.2V, 01=4.3V, 10=4.35V
          • bits 2-1 (read/write): (10 = after reset) overcharging of charging: 00=0mV, 01=14mV, 10=28mV, 11=42mV
          CHG_DIG_CTL4 = 0x25:
          • bits 4-0 (read/write): (10110 = after reset) charging current setting [A]:
            b0 x 0.1 + b1 x 0.2 + b2 x 0.4 + b3 x 0.6 + b4 x 1.4
          4. Charging information:
          Reg_READ0a = 0x70:
          • bit 3 (read only): charging status: 0 = not charging, 1 = charging
          Ref_READ0b = 0x71:
          • bits 7-5 (read only): detailed charging status:
            000 = inactivity
            001 = charging
            010 = constant current charging
            011 = charging with constant voltage
            100 = ??? (missing description in original document)
            101 = end of charging (maintenance current)
          • bit 3 (read only): signal of end of charging (=1)
          5. PIN assignment & control:
          MFP_CTL0 = 0x51:
          • bits 5-4 (read/write): (00 = after reset) pin LIGHT assignement: 00=WLED, 01=GPIO2, 10=VREF
          • bits 3-2 (read/write): (00 = after reset) pin L4 assignement: 00=L4, 01=GPIO1
          • bits 1-0 (read/write): (00 = after reset) pin L3 assignement: 00=L3, 01=GPIO0
          GPIO_CTL2a = 0x53:
          • bits 2-0 (read/write): (000 = after reset) GPIO[2:0] input enable
          GPIO_CTL2b = 0x54:
          • bits 2-0 (read/write): (000 = after reset) GPIO[2:0] output enable
          GPIO_CTL3 = 0x55:
          • bits 2-0 (read/write): (000 = after reset) GPIO[2:0] data
          6. Measurement:
          BATVADC_DAT0 = 0xA2:
          • pins 7-0 (read only): LOW 8 bits (byte) of BATVADC
          BATVADC_DAT1 = 0xA3:
          • pins 5-0 (read only): HIGH 6 bits of BATVADC
          Calculation according to the original document:
          BATIADC_DAT0 = 0xA4:
          • pins 7-0 (read only): LOW 8 bits (byte) of BATIADC
          BATIADC_DAT1 = 0xA5:
          • pins 5-0 (read only): HIGH 6 bits of BATIADC
          BATOCV_DAT0 = 0xA8:
          • pins 7-0 (read only): LOW 8 bits (byte) of BATOCV
          BATOCV_DAT1 = 0xA9:
          • pins 5-0 (read only): HIGH 6 bits of BATOCV
          This is true: BATOCV = BATVACD + BATIADC * battery_internal_resistnace
          7. WLED status:
          Reg_READ1 = 0x72:
          • bit 7 (read only): 0 = WLED is off, 1 = WLED is on
          8. Light / heavy load:
          Reg_READ1 = 0x72:
          • bit 6 (read only): 0 = heavy load over 75 mA, 1 = light load less 75 mA
          9. Button control:
          Reg_READ2 = 0x77:
          • bit 3 (read; write 1 = reset) flag button double clicked (=1)
          • bit 1 (read; write 1 = reset) flag button pressed (=1)
          • bit 0 (read; write 1 = reset) flag button clicked (=1)
          That is all.
          J E 2 Replies Last reply Reply Quote 0
            joyqat @JiKuch
            @jikuch Nice design.
            Do you have the I2C register document of IP5108? Could you share it? Thanks!
            • E Offline
              elecvoice
              Hi, can somebody tell me: if I change something in ip5108 through i2c, will it be saved, or i must make this changes each time when i start device?
              • E Offline
                elecvoice @JiKuch
                @jikuch
                Hi, can you tell me: if I change something in ip5108 through i2c (for example disable auto-standby), will this changers be saved, or i must make this changes (with software) each time when i start device?
