    Lcd driver for M5Stack Core2
    29 Posts 4 Posters 99.3k Views 2 Watching
    • W Offline
      Wolli01 @Russ
      @russ
      Many, many thanks!
      It works perfectly, you saved my project.
        Russ @Wolli01
        @wolli01 Excellent, glad it worked for you.
        • B Offline
          BricoMS @Russ
          • W Offline
            Wolli01
            @russ
            How can you include the internal SD card in your firmware? Do you have any ideas about this?
            I have not found anything yet.
            • W Offline
              Wolli01
              Found out now.
              It must be installed before the display driver in any case.
              #SD-Card
              uos.mount(machine.SDCard(slot=3, sck=18, mosi=23, miso=38, cs=4,), '/sd')
              print(uos.listdir('/sd'))
              • W Offline
                Wolli01
                Leider kommen diese Fehlereldungen wenn ich was speichern will. Das lesen geht.
                E (39687) sdmmc_cmd: sdmmc_read_sectors_dma: sdmmc_send_cmd returned 0x107
                E (39697) sdmmc_cmd: sdmmc_write_sectors_dma: sdmmc_send_cmd returned 0x105
                • W Offline
                  Wolli01
                  I load the SD driver after the LCD everything goes but the screen is not displayed.
                  If I load the SD driver before the screen, the SD does not work.
                  Something interferes then.
                    Russ
                    I was able to make concurrent display and sdcard work on the original M5Stacks https://github.com/russhughes/TinyBigBuckBunny but have not been able to make it work on the Core2's yet. I'm not sure why yet.
                      Russ
                      I was able to get simultaneous display and sdcard access working. The M5CORE2 firmware.bin has been updated. See the tbbunny.py example from https://github.com/russhughes/ili9342c_mpy/blob/main/examples/M5CORE2/tbbunny.py
                      W 2 Replies Last reply Reply Quote 1
                      • W Offline
                        Wolli01 @Russ
                        @russ
                        Thank you for your work.
                        It works now.
                        • W Offline
                          Wolli01 @Russ
                          @russ
                          Hello, is there any way to use the three touch buttons as well?
                            Russ
                            Yes, I’ll add an example working with the touchscreen later tonight.
                            • W Offline
                              Wolli01 @Russ
                              @russ
                              Super!
                              Thank you for doing this work.
                                Russ @Wolli01
                                @wolli01 Updated repo with two examples using the touchscreen. The buttons on the Core2 are actually part of the touchscreen that extend below the display from about Row 240 to 279.
                                Button press example:
                                https://github.com/russhughes/ili9342c_mpy/blob/main/examples/M5CORE2/buttons.py
                                Very simple paint program:
                                https://github.com/russhughes/ili9342c_mpy/blob/main/examples/M5CORE2/paint.py
                                • W Offline
                                  Wolli01 @Russ
                                  @russ
                                  Thank you very much for your effort.
                                  What is this code for in the end?
                                  Is it mandatory to use it?
                                  finally:
                                      # shutdown
                                      spi.deinit()
                                    ajb2k3 @Wolli01
                                    @wolli01 said in Lcd driver for M5Stack Core2:
                                    @russ
                                    finally:
                                        # shutdown
                                        spi.deinit()
                                    The code de initialises the SPI bus so that that other functions can use the pins or the bus
                                    • W Offline
                                      Wolli01 @ajb2k3
                                      Thanks for the info.
                                      Where is the best place to put it in the code
                                        Russ @Wolli01
                                        @wolli01 At the very end of the program before it quits.
                                        W 2 Replies Last reply Reply Quote 0
                                        • W Offline
                                          Wolli01 @Russ
                                          • W Offline
                                            Wolli01 @Russ
                                            @russ
                                            I have a problem with the SD card.
                                            My program runs sometimes 1-2 days well through and then when it comes to an error and hangs, it is restarted by the watchdog. When restarting but then no longer the SD card with the command:
                                            sd_device = sdcard.SDCard(spi, cs=Pin(4), baudrate=20000000)
                                            installed.
                                            Do you have a tip what this could be and how I can change it?
