    95 Posts 22 Posters 744.9k Views 10 Watching
      HOW
      Hello Rop,
      thank you very much for your quick answer and the "patch".
      Now it compiles (with old esp32 libary)
      It works perfect, great work!
      Have a nice day.
        janseta
        Hi Rop,
        I have another request ...
        An NTC or RTC Clock service (or both) can be incorporated ...
        For many applications it is necessary to know the clock time.
        It would be ideal to synchronize the clock via NTC every time you connect to a new Wifi, and / or also every so often (every 2 hours, every day ...)
        As I have been able to read, the ESP32 has RTC, but is made for the internal synchronization process, and has poor accuracy. https://www.esp32.com/viewtopic.php?t=3715
        A solution seems to be here:
        You can set the time in the same way as in the example
        ESP8266 / NTP-TZ-DST
        (see constant RTC_TEST) (it is the time of time - seconds since January 1, 1970), for this you can use two or three buttons (SET, + or / and -) and a screen, as in many clocks and appliances.
        • RopR Offline
          Rop @HOW
          @how Thank you for using M5ez.. :)
          You still want to switch to the latest library version though: other things (esp. Wifi) are much more stable with it.
          • RopR Offline
            Rop @janseta
            @janseta Thanks...
            Some things are on my list:
            • an inactivity timeout to power down if not using it
            • backlight setting
            Both would be stored in flash and settable from a settings menu that also incorporates the Wifi menu, so create a new linkable "Settings" menu a level higher. I guess I can also include an NTP clock, I'll see..
              Calin
              You can use nvs wrapper "preferences" for storing values that must survive reboot and even flashing: https://github.com/espressif/arduino-esp32/tree/master/libraries/Preferences
              Also Arduino-esp32 provide an integrated NTP library: https://github.com/espressif/arduino-esp32/tree/master/libraries/ESP32/examples/Time
              • RopR Offline
                Rop @Calin
                @calin Hi Calin. I already use Preferences in the new wifi code to store the SSIDs and passwords and a general flag whether autoconnect is on. Thanks for the NTP pointer...
                  r_255
                  Just got my m5
                  I am novice on programming and got it working!
                  awesome..
                  Also love the example file with the systeminfo,
                  i hope to make a mqtt remote out of it and this should make it possible for me!
                  Also got a question/request: it is possible to make the menu rotating? so last one down, will be the 1st one up?
                  offtopic
                  some how the quarter just falls here, something with old phone booths and dtmf beepers. lol
                  RopR 2 Replies Last reply Reply Quote 0
                  • RopR Offline
                    Rop @r_255
                    @r_255
                    awesome..
                    Cool! People like you are why I wrote it: programming needs to be easy and fun so more people get into it!
                    mqtt looks cool! If you're going to use the FACES keyboard, you will probably need ez.textBox, which I have on the drawing board. It will allow for both entry and display of longer texts.
                    I am currently testing features where you can replace up/left at the beginning or right/down at the end with a button name and caption of your choosing. Combined with the two new reserved button names 'first' and 'last', you can do that as well as lots of other clever tricks. (Like exit back out of a menu very easily, or make 2-D seeming menus by having the main image menu be horizontal and submenus (text or image) be vertical. So that's coming...
                    offtopic
                    • RopR Offline
                      Rop @r_255
                      @r_255 I just added the feature that allows menu rotation to the repository. upOnFirst and downOnLast properties can replace those navigation buttons with whatever you want. In fact, the main menu in the demo app now rotates, so you can see how it's done there, or in the README documentation for details.
                      Also: I changed around how MAIN_DECLARED works in the examples: it is now defined as true or false meaning you can just use its value from code instead of needing variables or #ifndef lines.
                        r_255
                        @Rop
                        Omg, you have been busy... :)
                        I am not going to use the keyboard, even it looks nice...
                        I need stuff ( remote ) to be plain simple as i have to deal with people that hold the mouse upside down.
                        so 3 buttons is more than enough ;) for this purpose.
                        i am off to github doing some exercises and read some code.
                        big thanks and a huge smile !
                        • RopR Offline
                          Rop
                          Just released 1.0.0 as I think it's pretty stable. Also I applied to have M5ez included in the Arduino library manager.
                          • RopR Offline
                            Rop
                            I just released version 1.1.0 of M5ez. It adds ez.textBox to display or edit longer word-wrapped texts. ez.msgBox now wraps and justifies, so you don't have to figure out how much fits on a line. And there's a dark theme added to the themes directory.
                            • B Offline
                              bobolink @Rop
                              @rop
                              Rop,
                              Great work. Professional appearance.
                              Can you offer any guidelines for preparing jpg images as a C array?
                              I’ve tried various on-line and command line converters but no image appears.
                              • RopR Offline
                                Rop @bobolink
                                @bobolink I haven't tried to convert any images myself, I have just taken the ones from Calin's code. I have been busy getting the new version out. I'll have a look at possibly creating a tool (or even an online tool) for this.
                                • RopR Offline
                                  Rop
                                  Just released: version 1.2.0 of M5ez.
                                  • It adds the ezProgressBar class to (you guessed it) show a progress bar while also offering all the word-wrapping niceties of ez.msgBox.
                                  • ez.update lets you specify an https URL to download a new binary from. And this wouldn't be M5ez if all of that wasn't extremely easy. the /tools directory of the repository has a shell script that people here might find handy even if they don't use M5ez. (But why on earth would you not use M5ez? :) )
                                  • The script, get_cert, takes an https URL as an argument. It will follow any redirects, output the resulting "effective URL", get the certificate chain, take the last cert from that, and make an include file that holds the root cert, ready to be used in your sketch. Below is an example.
                                  your_prompt$ ./get_cert https://github.com/ropg/M5ez/blob/master/compiled_binaries/M5ez-demo.bin?raw=true
                                  The effective download URL (after resolving forwards) is:
                                      https://raw.githubusercontent.com/ropg/M5ez/master/compiled_binaries/M5ez-demo.bin
                                  The root certificate include file is saved as:
                                      raw_githubusercontent_com.h
                                  • and then that file would contain:
                                  // This is the root certificate include file for raw.githubusercontent.com
                                  // as obtained by the get_cert script on: Wed Aug 15 21:34:20 CEST 2018
                                  // Certificate info:
                                  //     issuer= /C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert High Assurance EV Root CA
                                  //     notAfter=Oct 22 12:00:00 2028 GMT
                                  const char* root_cert = \
                                    "-----BEGIN CERTIFICATE-----\n" \
                                    "MIIEsTCCA5mgAwIBAgIQBOHnpNxc8vNtwCtCuF0VnzANBgkqhkiG9w0BAQsFADBs\n" \
                                    "MQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3\n" \
                                    "d3cuZGlnaWNlcnQuY29tMSswKQYDVQQDEyJEaWdpQ2VydCBIaWdoIEFzc3VyYW5j\n" \
                                    "ZSBFViBSb290IENBMB4XDTEzMTAyMjEyMDAwMFoXDTI4MTAyMjEyMDAwMFowcDEL\n" \
                                    "MAkGA1UEBhMCVVMxFTATBgNVBAoTDERpZ2lDZXJ0IEluYzEZMBcGA1UECxMQd3d3\n" \
                                    "LmRpZ2ljZXJ0LmNvbTEvMC0GA1UEAxMmRGlnaUNlcnQgU0hBMiBIaWdoIEFzc3Vy\n" \
                                    "YW5jZSBTZXJ2ZXIgQ0EwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQC2\n" \
                                    "4C/CJAbIbQRf1+8KZAayfSImZRauQkCbztyfn3YHPsMwVYcZuU+UDlqUH1VWtMIC\n" \
                                    "Kq/QmO4LQNfE0DtyyBSe75CxEamu0si4QzrZCwvV1ZX1QK/IHe1NnF9Xt4ZQaJn1\n" \
                                    "itrSxwUfqJfJ3KSxgoQtxq2lnMcZgqaFD15EWCo3j/018QsIJzJa9buLnqS9UdAn\n" \
                                    "4t07QjOjBSjEuyjMmqwrIw14xnvmXnG3Sj4I+4G3FhahnSMSTeXXkgisdaScus0X\n" \
                                    "sh5ENWV/UyU50RwKmmMbGZJ0aAo3wsJSSMs5WqK24V3B3aAguCGikyZvFEohQcft\n" \
                                    "bZvySC/zA/WiaJJTL17jAgMBAAGjggFJMIIBRTASBgNVHRMBAf8ECDAGAQH/AgEA\n" \
                                    "MA4GA1UdDwEB/wQEAwIBhjAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIw\n" \
                                    "NAYIKwYBBQUHAQEEKDAmMCQGCCsGAQUFBzABhhhodHRwOi8vb2NzcC5kaWdpY2Vy\n" \
                                    "dC5jb20wSwYDVR0fBEQwQjBAoD6gPIY6aHR0cDovL2NybDQuZGlnaWNlcnQuY29t\n" \
                                    "L0RpZ2lDZXJ0SGlnaEFzc3VyYW5jZUVWUm9vdENBLmNybDA9BgNVHSAENjA0MDIG\n" \
                                    "BFUdIAAwKjAoBggrBgEFBQcCARYcaHR0cHM6Ly93d3cuZGlnaWNlcnQuY29tL0NQ\n" \
                                    "UzAdBgNVHQ4EFgQUUWj/kK8CB3U8zNllZGKiErhZcjswHwYDVR0jBBgwFoAUsT7D\n" \
                                    "aQP4v0cB1JgmGggC72NkK8MwDQYJKoZIhvcNAQELBQADggEBABiKlYkD5m3fXPwd\n" \
                                    "aOpKj4PWUS+Na0QWnqxj9dJubISZi6qBcYRb7TROsLd5kinMLYBq8I4g4Xmk/gNH\n" \
                                    "E+r1hspZcX30BJZr01lYPf7TMSVcGDiEo+afgv2MW5gxTs14nhr9hctJqvIni5ly\n" \
                                    "/D6q1UEL2tU2ob8cbkdJf17ZSHwD2f2LSaCYJkJA69aSEaRkCldUxPUd1gJea6zu\n" \
                                    "xICaEnL6VpPX/78whQYwvwt/Tv9XBZ0k7YXDK/umdaisLRbvfXknsuvCnQsH6qqF\n" \
                                    "0wGjIChBWUMo0oHjqvbsezt3tkBigAVBRQHvFwY+3sAzm2fTYS5yh+Rp/BIAV0Ae\n" \
                                    "cPUeybQ=\n" \
                                    "-----END CERTIFICATE-----\n";
                                  Does that make life super ez or what?
                                  If you want, please check out the project github as well as the step-by-step description of how to use get_cert and ez.update. The OTA functionality is shown in the project demo app downloading via https from github and everything is documented rather nicely if I may say so myself. :)
                                    Calin @Rop
                                    @rop 在 M5ez, a complete interface builder system for the M5Stack as an Arduino library. Extremely easy to use. 中说:
                                    Open the file on HexWorkshop -> CTRL+A -> Edit -> Copy As -> C Source
                                    Open the header file -> Paste :)
                                    • RopR Offline
                                      Rop @bobolink
                                      @bobolink There is now an include_file script (here) in the /tools directory of the M5ez repository. If you get it, make it executable with chmod a+x include_file and run it with a file as an argument, like:
                                      your_prompt$ ./include_file settings.jpg
                                      Converting input file:
                                      Creating include file:
                                          settings_jpg.h
                                      That include file then contains:
                                      #pragma once
                                      // Include this file to use settings.jpg (1087 bytes) in your sketch.
                                      // File created on Thu Aug 16 11:39:50 CEST 2018
                                      // Made by the include_file script that is part of
                                      // "M5ez: the easiest way to program on M5Stack."
                                      // https://github.com/ropg/M5ez
                                      const char settings_jpg[] PROGMEM = {
                                          0xff, 0xd8, 0xff, 0xe0, 0x00, 0x10, 0x4a, 0x46, 0x49, 0x46, 0x00, 0x01, 0x01, 0x00,
                                          0x00, 0x60, 0x00, 0x60, 0x00, 0x00, 0xff, 0xe1, 0x00, 0x8c, 0x45, 0x78, 0x69, 0x66,
                                       snip [...]
                                          0x35, 0xf4, 0x0a, 0x6e, 0x75, 0x6b, 0x92, 0xab, 0xf6, 0x8b, 0x8d, 0x91, 0x79, 0x3e,
                                          0x50, 0x8e, 0x30, 0xbb, 0x49, 0x90, 0x03, 0xff, 0xd9
                                      Once this file is included, you can then provide the settings_jpg as the first argument to ez.addItem if you are adding an item to an image menu.
                                      • B Offline
                                        bobolink @Rop
                                        @rop Thank you. I’ll check it out.
                                        I think this is HexWorkshop mentioned above. .EXE for Windows.
                                          janseta
                                          Avesom work @Rop .
                                          Still waiting for NTC/RTC time issue... ;-)
                                          • RopR Offline
                                            Rop @janseta
                                            @janseta I am loosely thinking about adding:
                                            • NTP time and also an inactivity power-off
                                            • A settings menu with
                                              • link to the wifi menu
                                              • NTP on/off, which server(s) and sync interval
                                                • clock display in header on/off
                                              • display backlight brightness
                                              • FACES keyboard support on/off
                                              • Setting up the M5Stack peripherals (which GPIOs etc)
                                            But everything I add adds code size. So there probably there will be a few more code blocks like the present #ifndef M5EZ_WITHOUT_WIFI to allow people to not compile what they do not need.
                                            But before I get to this I need to figure out why the .setTimeout method does not seem to affect the https transfers for the firmware because they timeout way too often.
                                            Everyone: please feel free to suggest new features or tell me what you think about the proposed ones above.
