    [Core2] Touch event handlers in [MicroPython]?
    3 Posts 3 Posters 7.7k Views 2 Watching
      mb
      Does Core2 support touch event handlers in MicroPython?
      I would like to define my own touch interface:
      alt text
      So far I only found the M5Btn class, but I can not use it to define transparent touch tiles.
      from m5stack import *
      from m5stack_ui import *
      from uiflow import *
      screen = M5Screen()
      screen.clean_screen()
      touch_button0 = M5Btn(text=None, x=0, y=0, w=100, h=80, bg_c=None, text_c=None, font=None, parent=None)
      def touch_button0_pressed():
        # global params
        pass
      touch_button0.pressed(touch_button0_pressed)
      alt text
      I tried to overwrite the button with my touch tiles, but after press the button is shown.
      lcd.fillRect(   0,   0, 100, 80, 0xff0000 )
      lcd.fillRect( 100,   0, 120, 80, 0x00ff00 )
      lcd.fillRect( 220,   0, 100, 80, 0x0000ff )
      lcd.fillRect(   0,  80, 100, 80, 0xaa0000 )
      lcd.fillRect( 100,  80, 120, 80, 0x00aa00 )
      lcd.fillRect( 220,  80, 100, 80, 0x0000aa )
      lcd.fillRect(   0, 160, 100, 80, 0x550000 )
      lcd.fillRect( 100, 160, 120, 80, 0x005500 )
      lcd.fillRect( 220, 160, 100, 80, 0x000055 )
      alt text
      Or do I need to do this manually in a loop?
      import time
      def tile(x,y):
          qx = 0
          qy = 0
          if x>=0 and x<100: qx = 1
          if x>=100 and x<220: qx = 2
          if x>=220 and x<320: qx = 3
          if y>=0 and y<80: qy = 0
          if y>=80 and y<160: qy = 3
          if y>=160 and y<240: qy = 6
          return qx + qy
      def action(q):
          if q == 0: lcd.clear(0xFFFFFF)
          if q == 1: lcd.fillRect(   0,   0, 100, 80, 0xff0000 )
          if q == 2: lcd.fillRect( 100,   0, 120, 80, 0x00ff00 )
          if q == 3: lcd.fillRect( 220,   0, 100, 80, 0x0000ff )
          if q == 4: lcd.fillRect(   0,  80, 100, 80, 0xaa0000 )
          if q == 5: lcd.fillRect( 100,  80, 120, 80, 0x00aa00 )
          if q == 6: lcd.fillRect( 220,  80, 100, 80, 0x0000aa )
          if q == 7: lcd.fillRect(   0, 160, 100, 80, 0x550000 )
          if q == 8: lcd.fillRect( 100, 160, 120, 80, 0x005500 )
          if q == 9: lcd.fillRect( 220, 160, 100, 80, 0x000055 )
      def loop():
          x = -1
          y = -1
          while True:
              if touch.status() == True:
                  t = touch.read()
                  tx = t[0]
                  ty = t[1]
                  if x != tx and y != ty:
                      x = tx
                      y = ty
                      q = tile(x, y)
                      action(q);
              else:
                  x = -1
                  y = -1
                  action(0)
              time.sleep(0.05)
      loop()
      • V Offline
        vince94
        Hello
        Sorry if this is not helping (i am new to m5stack),
        isn't faq #56 close to this issue ?
        • Q56: I used UiFlow to write the Core2 drawing board program. Why did the drawing trace disappear after releasing the hand?
          Core2 has used LVGL and normal GUI drawing so far. Your drawing may use normal GUI API, but touch uses LVGL API, so LVGL touch triggers redraw and will overwrite the previous drawing traces. Use * Advanced*->Additional code Add the code "lv.obj.set_click(lv.scr_act(), False)" in the module to close the redraw event
        Can i ask if you found Python documentation for M5Btn object ?
        Thank you
          favnec5
          hello,
          i use the nice lvgl Lib to do That.
          1. create personalized button
          2. add event on the button
          example :
          import lvgl as lv
          screen = M5Screen()
          screen.set_screen_bg_color(0x00000)
          lv.init()
          # create screen
          scr = lv.obj()
          # set Background screen
          scr.set_style_local_bg_color(scr.PART.MAIN, lv.STATE.DEFAULT, lv.color_hex(0x000000))
          # create button
          btn = lv.btn(scr)
          btn.set_size(80, 80)
          # change style
          btn.set_style_local_bg_color(scr.PART.MAIN,lv.STATE.DEFAULT, lv.color_hex(0x0000ff))
          styleButton = lv.style_t() # create style
          styleButton.set_bg_color(lv.STATE.DEFAULT, lv.color_hex(0x0000ff))
          styleButton.set_radius(lv.STATE.DEFAULT, 0);
          styleButton.set_border_color(lv.STATE.DEFAULT, lv.color_hex(0x0000ff))
          btn.add_style(btn.PART.MAIN,styleButton) #define this style
          # callback action
          def action(btn, event):
            global src
            if(event == lv.EVENT.CLICKED):
              btn.set_style_local_bg_color(btn.PART.MAIN, lv.STATE.DEFAULT, lv.color_hex(0xffffff))
              btn.set_style_local_border_color(btn.PART.MAIN, lv.STATE.DEFAULT, lv.color_hex(0xffffff))
          # define callback
          btn.set_event_cb(action)
          # load the screen
          lv.scr_load(scr)
          best regards
          Thomas
          Thomas
